Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Looking for Mech. Speedo VSS (Behind Cluster)
Old Jul 4, 2006 | 11:36 AM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Axle/Gears: 3.55 8.8
Hey Guys,
I'm looking for a vehicle speed sensor and buffer assemebly (little yellow box with a few wires to VSS) that mounts to the back of the instrument cluster. These were used on all TBI engines thru 1992, all computer-controlled-carbureted engines, and on 1985-1989 TPI engines. I am usure of the part number.
Anyone got an old cluster with this on it?
Neil
Old Jul 4, 2006 | 05:23 PM
Zdrrguy's Avatar
Car: 1991 Camaro
Engine: 5.0L
Transmission: A4
Neil : I have one but I'm not sure you wanna drive to toronto to get it ??
Old Jul 5, 2006 | 07:12 AM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Thanks, for the reply..
I was actually able to get 2 yesterday at the local wrecker scam yard with some z28 guages, I just hope one works!
Old Jul 6, 2006 | 04:17 PM
Zdrrguy's Avatar
Car: 1991 Camaro
Engine: 5.0L
Transmission: A4
Well Neil , if you have no luck , mines here
Old Jul 7, 2006 | 02:05 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
I don't think the 85-89 had the VSS.
Old Jul 16, 2006 | 10:01 PM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
All cars with mech speedo's have them. I now have a few spares.
I found my problem, when I pulled the TPI and engine harness, the VSS ground got removed as it grounded through the engine harness to under the hood (all the way from the guage cluster!). After a alot of friggin and head scatching I got my cruise working again after simply regrounding the VSS at the connector near the old ECM where it tied to the engine harness. Nothing wrong with the old stuff after all. It was the only thing I didn't check on the list of things to check in the manual, seemed too obvious first time around. Always that way...
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
