Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Sway bars
Old Jul 21, 2006 | 03:59 PM
transamice's Avatar
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
Sway bars
What was the common size sway bars in 1987 Trans Am GTA's 305 TPI?
Was it 32mm front 19mm rear?
Old Jul 21, 2006 | 04:40 PM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
87's to '89's were equipped with 30 mm front shafts EXCEPT for those cars equipped with the FE2 option (suspension, ride & handling), in which case they had 34 mm shafts.
Rear shafts were 24 mm, including the FE2 optioned cars.
Old Jul 21, 2006 | 08:40 PM
transamice's Avatar
Car: 87 GTA t-top
I found a link all about GTAs that they used WS6 lvl 3 suspension, says sway bars are 36mm front 24mm rear.
Is that for real, didnt think stock were that big.
Old Jul 22, 2006 | 06:50 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
With sway bars its better if you check..Some got the bigger/hollow swaybars and some got the 32mm...I think its only certain for IROCs
Old Jul 22, 2006 | 08:33 AM
freestylzz's Avatar
Car: 1987 Iroc Z28
Here's the scoop. Looks like the 87 - 90 Camaro's with the FE2 had the 34 mm front sway. The 87 - 90 Birds with the FE2 had the 36 mm front sway.
Only from 91-92 did the Camaro's with the FE2 come with the 36 mm front sway.
Old Jul 24, 2006 | 04:40 PM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Axle/Gears: 3.55 8.8
I'm sure my 86 IROC has a 36mm on it.
Old Jul 25, 2006 | 06:22 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
My 87 IROC has 36mm swaybars..even bought 34mm moog bushings for it and it wouldnt fit
Old Jul 26, 2006 | 04:36 PM
freestylzz's Avatar
Car: 1987 Iroc Z28
I've done a search on the current General Motors Parts catalogue and there are no options or listings for 36 mm front sways on either the '86 or '87' camaro's.
That's not to say they didn't come with them. Go figure.
Old Jul 27, 2006 | 02:20 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
my 1989 has a 35mm sway bar up front. I guess that uear had 35 or 36 according to energy suspension.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
