Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Ac removal
Old May 3, 2007 | 08:57 PM
transamice's Avatar
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
Ac removal
I removed my ac now I have the 2 pipes sticking out the firewall where the blower fan is located.
Is there another connection inside the fan housing for me to unblot the ac pipes without cutting and is there a cover for a none ac option?
Do I have to adjust anything with the heatercore with this removal?
Old May 3, 2007 | 09:16 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Re: Ac removal
You can change it for a non a/c heater box
Old May 3, 2007 | 09:25 PM
transamice's Avatar
Car: 87 GTA t-top
Re: Ac removal
So I take it, this is a whole different setup and for me to actually remove that plastic housing I would need the whole setup from a non ac GTA etc...
Does the non ac hookup the same as the ac or is it a pain to hookup?
Old May 4, 2007 | 07:20 AM
mikieman98's Avatar
Car: 1985 camaro iroc-z
Engine: 350 4 brrl
Transmission: B&W T5
Axle/Gears: B&W 9 bolt 3.45
Re: Ac removal
hey there I have a non Ac box out of 89 formula that you might be interested in, They are actually easy to chane out.Have it listed in the ontario classified section or you can check it out at http://s185.photobucket.com/albums/x...t=100_5110.jpg
Old May 5, 2007 | 03:39 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
Re: Ac removal
just got the A/C ripped out of my IROC . I had a hard time finding a non A/C heater box that wasn't rotted out . Got one in London for 50 bucks. You may run into a problem with a bolt spinning ... but it comes off pretty easy . It take up a fair bit less room too . BUTTTTTTT with your A/C removed what are you doing about the belt ? I cut off the bracket for the compressor ( kept tensioner ) They do make an idler pully ... I couldn;t use it though as ...it sits right in front of the dam turbo ..so that was a no go
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
ctoledo0834
Sep 18, 2015 04:16 PM
Stroopwafel
Sep 11, 2015 06:38 AM
