Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Injectors ohms
Old Jul 27, 2007 | 01:53 PM
transamice's Avatar
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
Injectors ohms
Whats the spec for injectors resistance on an 1987 350 tpi setup?
I thought it was 15-18 ohms, anyone know different?
Old Jul 27, 2007 | 10:25 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Injectors ohms
Yes, 15-18 ohms when cold, and 13-15 ohms when hot. Anything less than 12 ohms and they're suspect. Anything less than 10 and they're dead.
Old Jul 28, 2007 | 12:19 AM
transamice's Avatar
Car: 87 GTA t-top
Re: Injectors ohms
Mine are coming up at 16.7 ohms all around when cold, I was told it was out of spec by AC Delco but I think other wise.
They tell me it should bt at 16.4,
Old Jul 28, 2007 | 08:19 AM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
Re: Injectors ohms
@ 16.4 is correct. Yours are still fine at those readings. Anything below a 15.9 and above 17 is suspect.
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
