Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Ecm scanning
Old Aug 9, 2007 | 01:56 PM
transamice's Avatar
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
Ecm scanning
Im having an issue with my mechanics scanning tool, engine seems to run fine but yet the scanning tool isnt reading properly.
Has anyone had such a problem, we hook the scanning tool to another ODB1 vehicle and it finds everything no problem.
I have 2 ecms and 2 proms Im trying out, I dont know what else to do.
Old Aug 9, 2007 | 08:20 PM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Axle/Gears: 3.55 8.8
Re: Ecm scanning
Did you check the wire/circuit from the ECM to the ALDL connector?
Old Aug 9, 2007 | 09:03 PM
transamice's Avatar
Car: 87 GTA t-top
Re: Ecm scanning
Seems to be ok from looking at it but I havent really tested it, thats my biggest fear that the harness or wires are pinched or burnt somewhere, its a bitch to figure out.
Old Aug 10, 2007 | 10:24 AM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Re: Ecm scanning
It's one wire from the ECM to the ALDL..easy check!
It's the one that you ground out at the ALDL to get the check engine light to flash codes. I think it's tan colour.
Old Aug 12, 2007 | 02:47 AM
transamice's Avatar
Car: 87 GTA t-top
Re: Ecm scanning
The car doesnt run good though, when throttled at around the 4000rpm it starts to fart and shoots to 5300 rpm then shifts but in the next gear it seems it shifted to early because the lack of power and low rpm.
At idle its fine, its only when throttle it acts up at higher rpm, still the ecm does not give proper readings, ALDL connector looks fine.
Old Aug 12, 2007 | 09:56 AM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Re: Ecm scanning
Mine did something like that about 10yrs ago, was a plugged cat.
It shifted weak and would fall on its face, and felt sluggish at higher rpms. The TPI's like to puke ignition modules if they don't have good heat sink compund under them as well..just some wild guesses here!
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
thunder57
Nov 7, 2015 02:28 PM
Jlanz55
Sep 29, 2015 08:55 AM
efiguy
Sep 27, 2015 01:30 PM
