87 TPI harness
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
87 TPI harness
Im trying to remove the ecm wiring harness but I noticed some components are meshed together, what comes off and what stays?
I plan on changing to carb, the ac control is sperated but the lighting is together with some of the ecm harness.
Another thing, how do I get the gromit of the wire harness out te fender way without cutting?
Car: 1989 GTA, 1985 T/A
Engine: L98, LG4
Transmission: Slush-o-matic 700R
Axle/Gears: stock and stock
Re: 87 TPI harness
Easiest way to solve your problem is to get a carbed harness...it will save you time and frustration. I think someone is parting a carbed Camaro on the CCFBG forum. You have to pull the fender off (at least partly) to get the harness through. I don't think you can separate the harness from the grommet...not sure though. Pretty sure the wiring and grommet are all tied in together. Good luck!
IBrockZ
Aug 20, 2015 12:20 PM
Sanjay
Aug 12, 2015 03:41 PM
