Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
vacuum line problem
Old Feb 18, 2008 | 01:02 AM
mikernet's Avatar
Car: 1989 Pontiac Trans Am GTA
vacuum line problem
Hey,
I tried posting about this a while ago but didn't get an answer, so I figured I'll try again.
My climate controls are stuck on defrost, and so I'm trying to find where the problem is.
How strong should the vacuum in the climate control lines be? At idle, I can't even feel the vacuum if i stick my finger on the end of the line. At about 3000 rpm, I can feel it very lightly.
Where does the vacuum come from on the engine? Is it the connection right under the throttle body? I stuck my finger on there but it doesn't seem to be sucking too hard from there either.
God I hate vacuum lines...
Old Mar 8, 2008 | 11:35 AM
gmanuel's Avatar
Re: vacuum line problem
On my 83 there is a little black bottle that is a vacuum a vacuum reservers (SP). Mine had a hole in it so I got no vacuum at the heater control. I bypassed the bottle and then discovered that the controller to control were the heat was to be deflected to was not seated properly and was leaking vacuuum. Basically look for vacuum lines going thought the firewall, look from the inside or the outside. I used a vacuum pump to help find my leak.
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
apie2546
Aug 10, 2015 05:43 PM
