Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Engine sensors
Old Jul 15, 2008 | 09:47 PM
transamice's Avatar
Car: 87 GTA t-top
Engine: L98 350 w/RMT
Axle/Gears: 9 bolt BW 3.45
Engine sensors
On an 87 TPI 350, what sensors are on the block?
I got the heat sensor on the drivers side, knock sensor on the pass side, is there 1 or 2 more sensors?
Old Jul 16, 2008 | 04:26 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Re: Engine sensors
fan switch on the passenger side,oil pressure switch driver side
Old Jul 16, 2008 | 07:54 PM
transamice's Avatar
Car: 87 GTA t-top
Re: Engine sensors
Just with the sensors and harness, I cant remem where the block sensors go.
I have 1 plug for a knock sensor but theres another sensor on the same side above the knock sensor that requies the same plug maybe little smaller but same style.
Only problem is I have 1 plug that style.
Could be because the setup I have is for an 87 and the engine is from an 89?
Old Jul 16, 2008 | 08:45 PM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
Re: Engine sensors
Its a fan switch(sensor).The bigger one is for the knock sensor. Maybe the fan switch is moved.
Old Jul 16, 2008 | 08:55 PM
transamice's Avatar
Car: 87 GTA t-top
Re: Engine sensors
Not sure but I know I dont have a plug for it then.
Do they look the same? (the plugs)
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
timonator
Aug 11, 2015 09:56 PM
