Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
twinturbo thirdgen build at schmitt tuning
Old Oct 23, 2012 | 10:34 PM
fultimekilla's Avatar
Transmission: 2000 t56
Axle/Gears: 8.8 hybrid/moser/tru trac/4.11s
Car: 1989 Camaro, originally 2.8 v6 5spd.
Build start date:summer of 2007.
Mods:
tubular k member, custom subframe connectors, 10 point rollcage
boxed rear lowered control arms, eibach sport lines, Kyb shocks, all polyurethane bushings, Sphoon 4th gen torque arm modified, ford 8.8 hybrid rear 4.11 gear, track lock diff 31 spline moser axles, chrome moly driveshaft.
Spec 3+ clutch, stock 4th gen t56 with short shifter. 4th gen brakes front
and rear, corvette 18" wheels.
6ltr lq4 (2003 gmc 2500 HD), arp rod bolts, arp
heAd studs, jwiz timing chain, cometic mls gaskets, patriot extreme
dual valve springs, otherwise stock motor.
Twin garret gt35rs turbos, dual 38mm tial wastegates, 50mm tial bov
custom stainless steel cold and hotside made me by me. Snow performance
stage 1 methanol kit, custom front mount intercooler.
4th gen fuel tanked sumped, Custom aeromotive fuel system, siemens 60lb injectors. Dbw setup, all autometer sport comp ultralite gauges, plus a ton of custom fabrication.
There are more mods but I can't remember now. I have. Ton of pics that I will be posting soon. Currently the car is about 90% ready for the dyno.
I will be posting numbers soon, I'm Hoping for atleast 550 rwhp at 10 psi or less.
https://www.thirdgen.org/forums/cana...gen-build.html
Old Oct 23, 2012 | 10:35 PM
Re: twinturbo thirdgen build at schmitt tuning
Terrell351
Jun 13, 2021 01:13 PM
NBrehm
Aug 25, 2015 11:49 PM
355tpipickup
Aug 13, 2015 07:35 AM
Jake_92RS
Aug 11, 2015 10:39 AM
