Need a 23MM rear sway bar
Car: 87 Camaro Iroc
Engine: 427 BBC
Transmission: TH-700R4
Axle/Gears: Bears Pro Street 3:73
Hi guys,
I need a 23 mm rear sway bar out of a iroc or ws6. If you are parting a car can you check the rear sway bar thickness? I could be off on the models that had 23 mm sway bars.
Thanks!
Tim
Thanks!
Tim
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: Need a 23MM rear sway bar
Did you ever find a 23mm rear sway bar?
1992rs/ss
16
Jan 28, 2016 09:58 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
