temp gauge out
Car: 1984 Z28
Engine: 355
Axle/Gears: 3.73 LS
Re: temp gauge out
does it read high the second you start the car? or just keeps climbing as the car heats up?
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Re: temp gauge out
Check the green wire on the drivers side head. Roughly located in the middle under your exhaust manifold. It clips into the sender and can come unclipped or the wire can get burnt on the exhaust.
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
Re: temp gauge out
See my post in Cooling section. Aftermarket sensors from parts stores can show 20-30deg too hot. You need the AC Delco original sensor, it fixed my gauge issues.
