what is your emision test results?
Car: Chrysler 300c
Engine: 5.7L Hemi
Transmission: 5spd auto
Axle/Gears: 2.89
passed like a new car even with a rusted out muffler!!!!!! my friend done the test at his shop
Moderator of the Southern Ontario board
1987 Trans AM
305 LG4 5.0L
WS6
700R4
142,000km
Black on gold trim
t- tops
K&N
Flowmaster 80 series
Sony X-plod deck
prestige 6 x 9s
2 crunch 10" bandpass
Boss 500w X 2 amp bridged to 2 Ohms
comming soon:
P275 50 R 16 on the back
(if they fit)
KILLS:
98 Mustang GT, 99? Dodge Ram 2500, 95 Acura Integra, 00 Cavalier (6 car lenghts!!!), many many ricers
1987 Trans AM
305 LG4 5.0L
WS6
700R4
142,000km
Black on gold trim
t- tops
K&N
Sony X-plod deck
prestige 6 x 9s
comming soon:
(if they fit)
KILLS:
Car: 1990 Iroc Z Convertible
Engine: LB9
Squeeked by, I had just finished my upper level engine rebuild and I had not put the car on a timming gun. They had to get the cat really hot in order for it to pass.
1990 Iroc convertible,305 tpi,Black with black leather interior,lowered,Taylor 8mm wires,K&N's
I was just hit by that bug.... just finished reinstalling all of my A.I.R. system including a hose to my collector pipe and a new one back to my CAT... i retest wednesday... Wish me luck..
Last test i was 290 ppm for HC limit 130 and .98% CO, limit .39.... i passed my NO though....
Mike
88 Iroc-Z 350 tpi, Hedmann Headers, 3" Cat Back, MSD Ignition, K&N, AirFoil
Mike
I haven't got my Drive Clean reminder yet - my birthday is in the fall. I don't have the AIR hooked up anymore (pump is seized) since I put in the SLP headers and full exhaust. I understand from the other boards here that you should have the car really warmed up when you do the test so that the CAT is working optimally. Hopefully I can pass OK. The motor has never been touched inside so I do get the blue puff of smoke at startup (bad valve seals) but she runs great otherwise!!
1984 Z28
L69, CC Quadrajet
K&N Filter
3.73 Limited Slip
Centerforce DF Clutch
SLP 1 5/8 headers, high flow CAT, SS Exhaust
GM Motorsports Struts
1984 Z28
L69, CC Quadrajet
K&N Filter
3.73 Limited Slip
i failed badly without my air... some places won't even test if it is missing.... unless you know someone be prepared to reinstall it... i had to reweld a diaphragm into my collector pipe of my headers since i didnt have air tubes on my headers... I hope it will be enough
Anyone with a TPI and 160 thermostat try the emisions test yet? I'm thinking maybe I should reduce my fuel pressure from 50 back down to about 47psi and make sure it's hot enough.
That's if I get the car on the road this year, looking for house
1992 Camaro Z28 L98
1997 K2500HD 6.5TD L65
1998 Yamaha WR400F
1988 Yamaha FZ750
1985 Yamaha RZ500
1999 Ski-doo MXZ600
1992 Camaro Z28 L98
1998 Yamaha WR400F
1988 Yamaha FZ750
1985 Yamaha RZ500
1999 Ski-doo MXZ600
Car: '87 IROC
Transmission: TH700R4
Here is an the word on hotrods from the drive clean web site:
Question:What happens if I change(d) the motor in my Light-Duty vehicle?
Answer: If the vehicle is included in the program (appropriate age, registered in the program area), it will be considered a hot rod if the motor differs from what was originally offered by the
manufacturer for that particular model year. Up until 2001, all hot rods will be tested
according to emission standards for 1980 vehicles. In 2001 and afterwards, vehicles
registered as model years of 1999 or earlier will continue to be tested according to 1980
emission standards. Vehicles registered as model year 2000 and later will be tested
according to emission standards for their model year. Vehicles built to non-Canadian
standards but imported into Canada will be tested similarly. Other specialty vehicles
registered as kit cars or 're-built' will be tested similarly in 1999 and 2000 and then tested according to appropriate emission standards for the model year.
ZFORCE,
Does that mean I can classify my car as a hot rod and use the 1980 emissions parameters since I have modified the car somewhat?
John
1984 Z28
L69, CC Quadrajet
K&N Filter
3.73 Limited Slip
John
1984 Z28
L69, CC Quadrajet
K&N Filter
3.73 Limited Slip
Car: '87 IROC
marin84
I am not sure what that statement is supposed to mean! I guess when you take your car in you will have tell the technician that your car has been modified and should be tested under the 1980 guidelines as per the statement from the website.
That is the process I am going to take when I receive the notice next year.
Z
Z
Car: 1992 Z28
Engine: 355
I'm not sure I get it.Does that mean my 1992 camaro will be evaluated as an '80 ? I imagine they still want all the emmisions equipment to be there.I'm just hoping for the best when it gets to my area.
92Z28
89GTA
92Z28
89GTA
Definition of Hot Rod for Drive Clean purposes: hot rod - "means a motor vehicle in which the original motor has been replaced with a motor of a type not installed by the manufacturer on that model of motor vehicle for the model year designated for the motor vehicle by the manufacturer". These are the exact words from the Drive Clean pdf file on the website http://www.driveclean.com/ so that means that I will have to pass the emissions test for my year of vehicle.
1984 Z28
L69, CC Quadrajet
K&N Filter
3.73 Limited Slip
1984 Z28
L69, CC Quadrajet
K&N Filter
3.73 Limited Slip
Got my car tested yesterday and it passed. I was about to fall on the floor laughing because the car should NOT of passed. The guy goes out and checks for leaks - I think he was a janitor, not a mechanic. There's only one bolt connected to the cadalidic converter and then there's a hole where the pipe was cut and reconnected using a "not-done-by-a-mechanic" method.
Second, you could actually HEAR an exhaust leak near the engine. I didn't even think they'd put it on the dino, but they did and she passed. I did do some things to help out though: I used that "guaranteed to pass" stuff, put in premium (god, it's expensive) gas and did an oil change. You might want to do the same if you're going for a test soon. Oh, this was done at a dealership too, just so you know.
Second, you could actually HEAR an exhaust leak near the engine. I didn't even think they'd put it on the dino, but they did and she passed. I did do some things to help out though: I used that "guaranteed to pass" stuff, put in premium (god, it's expensive) gas and did an oil change. You might want to do the same if you're going for a test soon. Oh, this was done at a dealership too, just so you know. Well i passed my retest... just barely!! i was just under the HC limit by 3 ppm... As for the HotRod route... I had many heated arguments with Driveclean Tech Reps... Basically if you have a non original block in your car that was not manufactured for that model year then you are a hot Rod... For example... if you have an 88 Iroc with a 400 Small Block that is a hot Rod.. If you have an 88 Iroc with an engine that has been bored out .030 with Aftermarket ignition headers high performance cam etc... that is not a Hot Rod...
I asked the question.." so if i have a Chevette an it only came with a 1.9l 4cyl and i put a 2l 4cyl in it is that a hot Rod?"
answer: "Yes, if that engine was not avalable that year"
My reply: "But my car isnt? that s bullsheet!
But i reinstaled my smog pump and ran an airline into my crossover pipe and ran Sunoco 94 octane and passed... Yippy...
Mike
Mike
Car: 1992 Z28
Engine: 355
My Z28 has an LT1 block from a '70 vette with an aftermarket 400 crank.What will my results be cross referenced with?
92Z28
89GTA
92Z28
89GTA
Car: '87 IROC
What if I just told the tech. that I have a 355ci from a vette? How will he know if it is the original engine or not. These tests go quick will they have the time to check all the numbers from the block?
tj
Black '87 IROC 350 TPI T-top headers 3" exh. MSD, all the ususal stuff
tj
Car: '85 IROC
It depends if the tech wants to crawl around with a wire brush and a mirror to identify the block. I have an L69 motor with a "GM 350 hp cam" in it and the car originally came with an LG4, so to my way of thinking, it's certainly "changed" or "modified" and should be classified as a hot rod. However, I have emailed DriveClean several times over the last couple of years to clarify this and each time I get a different answer. When my time comes in November 2002, it will probably be up to the tech that does it. I'm also missing an EGR valve and the charcoal cannister plumbing for it, although I put in a cannister from another Camaro and connected it to the gas tank vent tube. The car also does not have an AIR pump system and I don't even know if it's supposed to, since my '83 LG4 didn't. However, the engine does have L82 Corvette valve covers, so maybe I can convince them it's a Corvette engine.
1985 Yellow IROC-Z 5.0 HO, T-5 3.73 Torsen, 4 wheel disks
PFCM pads, GTA wheels, Koni yellows, B&M Ripper, Dynomax
