ABSOLUTELY NEED 89+ REAR BACKING PLATES
Subject says it all. Anyone have any or know where I can get some? I need them so I can put the PBR 89 and later brakes on my 9 bolt. Let me know if you can help. Thanks Guys
1988 IROC-Z T-Top "MATTSTOY"
350 Crate engine
370ft. lb Torque out of the box
5speed, Centerforce clutch, Spohn Sub-frames & adjustable pan hard rod, Jamex 1.5' Lowering springs, 2 1/2' Exhaust,ram air setup, ported and polished plenum, soon 3.45 9 bolt rear end with discs!
350 Crate engine
You can buy backing plates at any parts store- i.e. Crappy Tire or UAP/NAPA, wherever- just specify make and model you want 'em from. Also, usually there are some variations: 2-Piece backing plate (so you don't have to yank out axles), a 1-piece (like factory) and with or without the hydraulic wheel cylinder.
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
