Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Advance the timing ?
Old Jan 29, 2002 | 08:25 AM
palric's Avatar
Car: 90 IROC 5.7 hardtop
Transmission: T5 swap
Axle/Gears: Yup -- they still work
I was reading in one of the car mags, Hi-Perf Chevy I think, that a tuner trick was to advance the timing on the TPI motor by 12 degrees. This makes for alot more torque down low -- or so says the mag writer.
Can anyone verify this ? Has any of you tried this and had any meaningful/positive results ?
Thx in advance,
RP.
Old Jan 29, 2002 | 09:20 AM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Is the article refering to base timing? The factory setting is 6 degrees. Going past 8-10 degrees probably would not be a good idea. I have an article from High Tech Performance that goes over the procedure and results. Actually I have 2 articles. They both deal with mass air cars but the results will be the same on a speed density car. If you want I can scan them and send them out.
Old Jan 29, 2002 | 09:34 AM
palric's Avatar
base timing
As far as I know it was 12 degrees total advance so an increase of an additional 6 degrees. Yes, thx, please send the articles.
Do you run your car advanced ?
RP.
Old Jan 29, 2002 | 10:22 AM
nblanchard's Avatar
I know with my PRM Chip, I have to advance timing until I get a tad detonation, for a split second, shifting into secind, then back it off a tad. I have no idea what degree this would be. I'll ask what my buddy put his ad.. or... if BILLZ88350 reads this, tell us what your timing is set at.
Old Jan 29, 2002 | 01:28 PM
88 IROC BOB's Avatar
I di some good testing last year at the track one day. I started out with the base timing set at 6* and made a run. I then tried it at 8, 10 and 12*. I found for my combo that 8* worked best for me. I didn't have a scan tool to check knock counts but went on the premise that my best mph was with it at 8*.
Bob
Old Jan 29, 2002 | 02:31 PM
Acceld Z's Avatar
Car: 1992 Z28
Engine: 355
Re: base timing
RP.
The only way you can change anything other than base timing is through PROM modifications. When I just had the basic bolt-ons I had the base timing set at 8 degrees. That was with an old HyperTech stage 3 chip. 8 degrees seemed to be the "sweet spot" where the ECM wasn't pulling timing out due to knock counts. I had a ton of help from some techs at Jack May Pontiac/Buick when doing this. I wouldn't consider taking timing past 8 degrees without being able to watch knock counts. I bent a bunch of valves before I had any opportunity to experiment with the timing this fall. The guy's at FastChip said it would perform best at 6 degrees. I will scan and send the articles tonight. Did I speak to you on the phone this past summer?
Old Jan 29, 2002 | 02:39 PM
palric's Avatar
Re: Re: base timing
... I will scan and send the articles tonight. Did I speak to you on the phone this past summer?
Yes we spoke on the phone. I was trying to buy your runners but was toooooo late, they were already sold. Then I was going to buy your heads but decided to keep my 305 instead of upgrading to a 350 which would have required your heads. Got any other SLP goodies for sale ?
RP.
Amillionoh7
May 24, 2020 08:01 AM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
Thirim
Aug 9, 2015 06:19 PM
djmarch
Aug 9, 2015 05:27 PM
