Third Gen Association of Ontario Regional message board for everyone in Southern Ontario and nearby regions.
Setting Idle
Old Feb 20, 2002 | 09:09 AM
nblanchard's Avatar
Setting Idle
Something that really really bugs me with those guys in the TPI forum... they all try to set the Idle on their TPI engines, then they f**k it up, and come crying... why isn't it running right, wah wah wah!!! Grrrrrr... GM doesn't put a cover over the throttle stop for nothing!!! I was told be a reliable GM Mechanic, is that the only way to adjust your idle properly is to get into programmin your own chips... the throttle stop will give you a tad bit of play, but if you take the screw out too much, it will cause your throttle blades to stick. Also, the computer wants the engine to idle at a certain RPM, so even if you do pull out the screw a bit, the computer is gonna see the RPM's drop and open the IAC more.. does anyone feel the same way about this? Because they are all talking to me like I am a dumb a$$.. and, to me, my theory makes total sense.
The reason why this has been bugging me, is because I want to lower my idle to about 600, to get more of a lumpy V8 sound But can't find an easy way to do it... one disadvantage of EFI... oh well... I suppose I can live with it...
Old Feb 20, 2002 | 09:38 AM
Daz's Avatar
Daz
Car: 87 Camaro
Engine: Chevy V8
Transmission: auto
check out the article about setting TPS and IAC.. i doubt that you can make it idle low enough to give it that "lumpy cam effect" without the ECM raising it back up..
Daz
specialized
Jun 18, 2022 09:26 AM
Andrew6.688
Dec 13, 2015 10:59 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Dialed_In
Aug 20, 2015 01:45 PM
perZ
Aug 15, 2015 01:17 PM
