need opinions for school assignment
HI,
I am writing a big paper for my advanced composition class and I need your opinions. The paper is about the best modifications for a third gen. firebird/camaro. The question is what would be the best mods for a tuned port injection engine.
Thanks for reading and responding
well...i dont know too much about this...but i guess you could branch your paper 3 (more or less) diff ways...you could go in to forced induction, NO2, and NA(high compression)
sorry to be so general...just getting the ball rolling and i dont want to give you any false info.
Mike
Mike
Car: 1988 Vette; 1988 IROC Z-28
Engine: 350cid; 305cid
Transmission: 700R/4; 700R/4
Axle/Gears: 2.59; 2.77
Since you have an '87 you already have some idea.
The "best" mods depends on your goal, the first step in any set of mods...set the purpose/goal. It's not the best mods buit rather the best combo of mods.
Anyway, assuming you want a "street rod" for strip/street and, since you specified TPI (LB( or L98), try these :
Exhaust-headers, hi-flow cat, cat-back.
Intake-ram-air, K&N, gutted MAF, 52mm TB, ported plenum, LT runners & base.
Ignition-hi-energy coil, low resistance wires, cut-back spark plugs.
cooling-160deg stat & fan sw, relocated MAT, TB coolant bypass.
parasitic-underdrive pulley set.
heads-pocket prorted Al heads, 3-angle valve job,large valves.
valve train-roller rockers on 7/16" studs w/ Ti retainers & 10deg locks, hardened guide plates & pushrods.
cam-roller (112LSA, 212/220int/exh @.050", .510"/.510" lift).
fuel-blueprinted injectors, AFPR, gauge on fuel rail.
CalPac-custom tuning of spark & fuel curves.
Now if you want a realy big paper, do some research to come with a "best" combo for a particular TPI motor (hmm, say an L98... in a GTA...). Have in mind some idea of a torque/HP curve as target.
Good luck with the project.
Pac J
May 17, 2020 10:44 AM
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
