help me to get my car to idle right
Old Apr 16, 2002 | 05:41 AM
86IrocZ383's Avatar
okay, I got the new stroker going this weekend and I can't get it to run well below 1500 rpm. It seems like it wants to roll all the time, it will be at 1500rpm and drop to 750 and back up, sometimes it settles down. I tried to set the Iac and it didn't really work, it would go as low as 1000, but if I give it a quick rev it would rev and die. Also I can be driving, let off the gas and it will roll again and die. Any help would be great.
Old Apr 16, 2002 | 07:52 AM
355formula's Avatar
im not too familiar with tpis yet, but maybe something clogging the fuel from getting to your engine? fuel filter, fuel pump... just my .2 cents
Old Apr 16, 2002 | 07:26 PM
86IrocZ383's Avatar
I don't think so everything is basically new, I don't think it has any vacuum leaks but I should take another look.
Old Apr 16, 2002 | 10:09 PM
355formula's Avatar
always double check those bastards. make sure you move them around to, like stretch them and ****. cause sometimes you cant see the crack until its stretched.
good luck
specialized
Jun 18, 2022 09:26 AM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
