cold start injector??
Old Apr 17, 2002 | 11:20 AM
SnkSknrZ28's Avatar
Car: 1988 Camaro IROC-Z
alright ive got an 87 IROC-Z. with the cold start injector, .. now i ran into a problem, i picked up a set of siamesed runners that are with out the whole for the cold start injector!. so 1. do i try and cut it out of the runner, 2. block off the injector, but i was told it helped start the motor, and with out it the motor wont turn over and run..
if anyone can help., let me know, thanks
shaun
Old Apr 17, 2002 | 11:21 AM
SnkSknrZ28's Avatar
this is my friends question, don't pay attention to the sig.. it is an 87 IROC.. thanx
Old Apr 17, 2002 | 04:58 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
i would believe the consensus around here would be block off the CSI and get and 89' bin and load it up. i would look into prom burning rather than runner cuttings. in 89' they eliminated the CSI and all 8 injectors "primed" the engine so no need for the CSI anymore. good luck
Old Apr 17, 2002 | 08:31 PM
SnkSknrZ28's Avatar
:lala: :lala: :lala: :lala: :lala:
so when i get my new engine combo back together and i get my PROM burned shoud i just have them program it to not ingage the cold start ingector?? but after i do this will the PROM automatically make my injectors pulsate to through the fuel down rather than having the CSI?? thanx shaun
Old Apr 17, 2002 | 09:14 PM
Car: 1988 IROC-Z
if you do that through the stock 87' bin, no it will not automatically pulse the 8 injectors. if you do load up a 89' bin for the appropriate engine/trans combo then it will automatically pulse all 8 since that is the way the new cold start system was designed w/o the CSI.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
