86 Iroc
Old Apr 19, 2002 | 09:49 AM
Mark W. Winning's Avatar
86 Iroc
I just picked up a running 86 IROC. It was a rear ender, so I planned to use it as a parts only car. I am planning on dropping everything into my 85 Camaro. I have done the search and read most of the postings on swapping the TPI 305 for a 350. My real question is that I plan to do a stock cammed 383 for it. If I change the chip, the knock sensor and go to the #22 injectors, should it be ok? I am not looking for a 11 second car here, just something with some low end ***** that is fun to drive and will not suck the tank dry each day.
Thanks guys...
Old Apr 19, 2002 | 10:23 AM
TBurke's Avatar
I went from a stock 305 long block to a 355 with a fairly mild cam(216 @ .050/.454 lift hydraulic) and a set of AFR 190's. I swapped everything over but switched to ADS 24lb injectors. I left the stock computer and the car ran great. Maybe a little rich but it had the stock drivabilty and made about 330 horse. You shouldn't have any problems.
Old Apr 19, 2002 | 10:24 AM
Jim 86 IROC's Avatar
Car: 1988 Vette; 1988 IROC Z-28
Engine: 350cid; 305cid
Transmission: 700R/4; 700R/4
Axle/Gears: 2.59; 2.77
The 22# injectors would be fine for a moderate 350/355 but on an 11sec IROC you'll need more flow. Also, a rule of thumb for max HP from a set of injectors is:
HP=RatedFlow * 8 / 0.5, assumes a BSFC of 0.5 for TPI.
I have a flow number table on my site for a rough guide. There are some equations that will allow you to calc the HP necessary for 11s if you know the weight of your IROC.
Old Apr 19, 2002 | 10:28 AM
TBurke's Avatar
He said he wasn't looking for 11's just a car with alot of low-end power. With a TPI intake a 383 would run out of steam at around 4700-5000. 22lb inj should feed this ting no problem.
11 seconds would be a different ball game.
BAMiller
Sep 14, 2015 06:38 PM
angel2794
Sep 8, 2015 06:22 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
g.l.mos
Aug 22, 2015 12:02 AM
mustangman65_79
Aug 11, 2015 03:17 PM
