i need suggestions please
Old Apr 21, 2002 | 08:16 PM
cherrybomb86's Avatar
i have an 86 tpi t/a car was runnning fine after few minor mods past summer. rear of intake was leaking due to cheesy end rail gasket . so i did it this past weekend only to have the car start and run rough. i believe i assembled everything properly and torqued properly. timing is fine too. could a crossed injector cause it to run like this? im going to run a compression test tommorow. it seems like timing or i could be getting air in from somewhere else. i also rtved the windage baffle on the underside of the manifold. if i cant figure this out im going to do it all over again next weekend. any suggestions would be appreciated from an experienced wrench please
p.s. this seems like a leak or valve adjustment, cracked plugg but just replaced. just poor timing i have replaced just about every sensor slash relay so iknow it isnt that also no codes have been tripped could i have possibly put the intakes on backwards the holes matched up im stumped and frankly pissed off at this point but life goes on and i know ill fix this..... all wires are firing fine to .... car has cam headers and chip 305 thgnk you people for any help in my meaningless trans am.......
Old Apr 22, 2002 | 02:17 AM
Jim 86 IROC's Avatar
Car: 1988 Vette; 1988 IROC Z-28
Engine: 350cid; 305cid
Transmission: 700R/4; 700R/4
Axle/Gears: 2.59; 2.77
If you only did the intake look first at everything you touched.
A vacuum gauge will tell you if you have any problems there. It's easy to miss a vacuum hose or crack an EGR hose.
Wring out the plug wires as an LB9 will run rather well with two crossed (don't ask).
Are you sure the dist is indexed correctly?
Old Apr 22, 2002 | 05:31 AM
yes sir everything checked out then double checked. i think a plug wire may be cooked ( its all brown due to confined space between lokar dipsrick and header tube.)so im pulling the [plugg before work this morning and i will know. otherwise i need to keep it simple thank you
Old Apr 22, 2002 | 11:01 AM
To check that wire clip a timing light onto it and hit the trigger. If the light's flasher are unsteady compared to a good wire you've found it.
I did this to find two pad posts on a dist cap recently.
Old Apr 22, 2002 | 11:52 AM
i pulled the plug and found it was fouled gonna replace wire and clean plug to see if it doesnt skip anymore. i have another question is there any way i can stay logged in to this site at all such a pain remebering my password. and how about the t-shirts id get one if they where cool and cheap i guess thats it thanx for your suggestions iroc wish you the best hopefully its just fouled plug(s) going to go to a local speed shop and investigate a set of accel 300+'s see what happens i guess later on..
Old Apr 22, 2002 | 02:06 PM
Sounds like you have it under control.
Go edit your Forum profile and check the box "stay logged in".
Old Apr 22, 2002 | 08:01 PM
thank you and have a good one sir.
darwinprice
17
Oct 11, 2015 11:51 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
gord327
Oct 3, 2015 01:25 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
R13_Braz
Sep 18, 2015 05:00 PM
