Leaky injectors cause gas in oil?
Old Apr 21, 2002 | 10:48 PM
PLANT PROTECTION's Avatar
Car: 1987 Monte Carlo SS
Transmission: 200-4R
Axle/Gears: 7.625 10 bolt/3.73s
My new Accel injectors seem to be leaking and they only have 5k on them. During a 20min oil change, my fuel pressure drops from 45psi to 0psi. The oil smelled of gas and I am trying to determine if it is from the injectors or when I had 3 fouled plugs.
Old Apr 21, 2002 | 11:03 PM
cherrybomb86's Avatar
that sounds real messed up could you elaborate more on the motor itself
Old Apr 22, 2002 | 01:34 AM
RedIrocZ-28's Avatar
Car: Iroc-Z
Engine: 355 AFR'd HSR
Yeah.. what motor do you have? Why did you get new injectors? How many miles does the motor have on it?
Old Apr 22, 2002 | 10:58 AM
Its a 89 L98 with 75k. I changed the injectors because 6 of them had inpedence values of 0-3ohms and the car wasn't driveable. The new injectors fixed the problem. Just recently, I had oil on plugs 1,3, and 7 and were fouled. The fuel pressure is dropping to quick correct? In another post asking about the plugs, they said a fouled plug will cause fuel to get dumped into the chamber and may slip past the rings into the oil.
Old Apr 22, 2002 | 11:58 AM
my advice to you would be to run a compression test at the very least to verify the compression around 120 psi on my car 305 is acceptable with minor deviation. a leak down test would also be effective for testing rings. not familiar with that procedure but would like some info on it. sounds like your in bad shape and new injectors only magnified it. i recently frazzled a plug wire and have experienced the fouled plugg. but gas in the oil doesnt sound good at all. hone it and rering it and it should solve your problem or better yet bore it out and get new pistons whatever you decide good luck. sounds like that mill was driven hard and put away wet. :rockon:
Old Apr 22, 2002 | 12:30 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
I had a short in my injection system which caused the injectors to open a lot longer than they were supposed to at times, and it resulted in diesel fuel in my oil pan. It took the shop 3 days to find the short in the line between the ECM and the engine.
Just something to keep in mind.
Old Apr 22, 2002 | 08:06 PM
wow thats a tough one, but sh*t happens i wonder how that shorted out id be interested to know was the wire chaffed and how did they repair in solder the wire please keep me informed and happy motoring......
jklein337
Sep 19, 2018 06:23 PM
Jae992
Aug 27, 2015 09:07 AM
Navy8125
Aug 21, 2015 09:32 AM
92camaroJoe
Aug 13, 2015 06:07 AM
