do we have this part.
Old Apr 22, 2002 | 05:27 PM
BLUEIROC5.7's Avatar
hey all i was just wanted to know if we have oil coolers. I have a 89 iroc 350 tpi. I just want to know
Old Apr 22, 2002 | 05:41 PM
rhuarc30's Avatar
I think the iroc's have 'em, I know my firebird came with one, not a real good one though.
Old Apr 22, 2002 | 05:42 PM
88ROC1LE's Avatar
I do and I have an 88, so I'm sure you do
Old Apr 22, 2002 | 05:55 PM
how can you tell if it is not working.
Old Apr 22, 2002 | 06:16 PM
IROCZZ3's Avatar
Car: 87 Buick GN
Engine: 3.8L (231 cid) V6
Transmission: 200-4R
Axle/Gears: 10 bolt G80/ 3.42
Not all IROCs have em....
My 89 IROC 5.7 w/700R4 and BW 9 bolt 2.77 did NOT come with a factory oil cooler.
But I'm not sure which ones had them....probably the 1LE's for sure???? Someone should be able to give you a definite answer.
Old Apr 22, 2002 | 06:19 PM
88ROC1LE's Avatar
If I'm not mistaken isn't the oil cooler a critical part when it is installed, if it wasn't working wouldn't there problems with oil press, etc? Why is you motor oil excessively warm or something?
Old Apr 22, 2002 | 07:23 PM
no my fans stay on all the time. But two weeks ago my oil presture sender went bad so i replaced it. It seams to be fine but when i drive foe a long time the gauge is low but not in thr red. So i think i am ok . Thanks for all the help guys. That why i love these cars and the people who drive them.:lala:
Old Apr 22, 2002 | 10:28 PM
89ProchargedROC's Avatar
The oil cooler was only an option on the 89+ cars with the dual cats/performance axle/oil cooler and only came with pre 89 cars when the performance axle ratio was checked
so tell me what year your car is, how many cats and what rear end
Old Apr 22, 2002 | 10:34 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Both of my GTA's had/have them. One was a 305/5speed, one is a 350/auto.
Old Apr 23, 2002 | 08:06 PM
89 iroc 350 singal cat, 9 bolt 2.77.
Old Apr 23, 2002 | 08:18 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
what about 88 gta 305 tpi auto 9 bolt with 3.27 gears? my friends gta had one it was a late 88 it had vats and the pbr rear calipers. we even double checked that it was an 88. it still had the cold start inj. though
Old Apr 23, 2002 | 10:01 PM
you *should not* have the oil cooler, but it has been noticed that every once in a while GM would screw up or some people had the dealer install the oil cooler at the dealer after it was bought WITHOUT the performance axle/dual cat/oil cooler package
it is easy to look for. There will be solid lines (big silver ones) running along the oil pan and going back by the oil filter and up over the rear of the block...if you dont have these lines, you dont have an oil cooler
Old Apr 23, 2002 | 10:03 PM
hmm.....now thats interesting. I didn't know you could buy the GTA with a 305. Maybe the trans ams had the 350 TPI
in my opinion, you *should* have an oil cooler denoted by the performance axle ratio. That was the case in my friend's iroc, but not sure because you have a 305 and am not familiar with what options they came with.
Refer to the location of the oil cooler from what i typed above
Old Apr 24, 2002 | 09:42 AM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
GTAs were standard w/ 350/Automatic, but orderable w/ 305 only w/ a stick, so your friends 305/Auto may be a fake GTA or something.
Matthew
racereese
Oct 10, 2015 09:39 PM
J.C. Denton
Sep 8, 2015 05:35 PM
sunbound
Sep 5, 2015 11:52 AM
Gambit TA
Sep 1, 2015 07:27 PM
Fox118
Sep 1, 2015 04:07 PM
