EGR questions - SD vs MAF
Old Apr 25, 2002 | 12:41 AM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
Is there a difference between the Speed Density EGR and the MAF EGR? My 87 EGR has a temp diagnostic switch, and my manual shows the correct ECM pin for the wire.
However it appears, that I am either not seeing it in the '730 ECM pin out (which is entirely possible as I have been known to miss obvious things ) or the '730 does not use this function.
So, do I need to buy a 90 - 92 EGR? Or will my 87 style EGR work ok with a Speed Desity set up?
Old Apr 25, 2002 | 03:12 AM
Jza's Avatar
Jza
The 7730 uses other methods to find out if the EGR valve is working or not, so you can just toss the diag. switch and use your current valve.
Old Apr 25, 2002 | 05:21 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
thanks :hail:
I might get this thing running this weekend afterall!
chazman
Aug 28, 2018 03:25 PM
mdtoren
Aug 23, 2015 12:52 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
mdtoren
Aug 16, 2015 05:45 PM
