Removing runners?
Old Apr 25, 2002 | 08:16 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Removing runners?
Any one got any tips to remove the runners off my TPI. I have my base and tb off. Will I have to remove or raise the fuel rail?
Are they any seals or o-rings to worry about with the fuel rail?
What about the injectors, will I have to remove any to get to the bolts.
Im not trying to sound dumb, and I did do a few searches, but I could not get clear info.
thanks.
Old Apr 25, 2002 | 08:32 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
As long as my head is on straight (which is never a sure thing in the morning), you should have no problem removing the runners w/ the fuel rail still on. And don't forget about the 'blind' bolt that you have to get to from behind (driver's sdie runner bolted from behind by the ditributor, pass side runner from behind by the front.
Old Apr 25, 2002 | 08:36 AM
Jim 86 IROC's Avatar
Car: 1988 Vette; 1988 IROC Z-28
Engine: 350cid; 305cid
Transmission: 700R/4; 700R/4
Axle/Gears: 2.59; 2.77
Don't foreget the two inner bolts at the runner base; left rear and right front. A Torx key or allen key works well to get at the left rear Torx bolt. For the outside Torx bolts a long 3/8" Torx bit works well with a swivel.
You should be able to work them out without removing the fuel rail.
Old Apr 25, 2002 | 08:39 AM
87transam5.7tpi's Avatar
ya you can take off the stock runners wifht te fuel rail. the SLP's you have to losen it, but still can leave it on.
Old Apr 25, 2002 | 08:41 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Thanks guys, You all replied Quick.
Any tips on polishing the runners.
Old Apr 25, 2002 | 09:06 AM
To just polish them I use Scotch Brite and some carb cleaner to cut the soil. Finish up with an Al polish.
If you have the $$ or facility glass beading would do the trick.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Stroopwafel
Sep 11, 2015 06:38 AM
toronto formula
Sep 10, 2015 07:31 AM
hydrolic144
Sep 8, 2015 06:59 PM
89fast5oh
Sep 8, 2015 09:55 AM
