one-mod HP gains
Old Apr 25, 2002 | 12:20 PM
91L98Z28's Avatar
Car: Z28
one-mod HP gains
Just wondering if everyone could post their "one modification only" horsepower/torque gains for TPI motors, as verified by chassis or engine dynos? I'm curious to see what the single biggest power adder bolt on is.
For example....in the recent stealth ram thread, the following was posted:
Originally posted by e-man
This is from a guy that works for holley
Here's the chassis dyno results!
Car is an automatic 1992 5.7L Camaro. Car is bone stock except cat back.
We added the stealthram and a Holley billet 58mm throttle body. That was the only changes. I don't think the throttle body makes much of a differenece at this power level.
This data is for 3rd gear RWHP on a dynojet.
RPM Stock HP Stealthram HP Diff
3400 190 175 -15
3600 200 188 -12
3800 209 198 -11
4000 210 204 -6
4200 212 210 -2
4400 213 223 +10
4600 214 234 +20
4800 210 240 +30
5000 198 239 +41
5100 184 238 +54
5200 174 237 +63
Wow! I have to wonder, if this means that the stock L98 exhaust manifolds can support up to 240HP, at least? Making a better intake a "better" bolt on than say, SLP headers?
Old Apr 25, 2002 | 12:37 PM
Jim 86 IROC's Avatar
Car: 1988 Vette; 1988 IROC Z-28
Engine: 350cid; 305cid
Transmission: 700R/4; 700R/4
Axle/Gears: 2.59; 2.77
I don't have any dyno pulls nor trap speeds on single mods but those are impressive numbers. From a dual cat setup no doubt.
I assume that was from replacing a stock TPI intake considering the drop in low end grunt.
Old Apr 25, 2002 | 01:30 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
If you ask me you're just opening a pandoras box of misinformation here. Results for mods will vary depending one what you have done already. I guess it'll be interesting to see if anything good shakes out though
edit....well i'd say the guy below me is a good one for this post, lol
Old Apr 25, 2002 | 05:36 PM
Jay's Avatar
Jay
Car: 88 IROC
Engine: 5.7 RamJet
Axle/Gears: Dana44 4.10
A friend of mine has a completely stock 91 305 engine. Not even so much as an AFPR and he is getting 320 HP and 370 TQ at the rear wheels using a ProCharger. This is through stock 305 exhaust manifolds and dual cat Y pipe, and an Edlebrock catback.
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
IROCThe5.7L
Sep 17, 2015 07:48 AM
