heres a simple one.....
Old Apr 26, 2002 | 05:20 AM
cherrybomb86's Avatar
does anyone know an appropriate way to torque the plenum and runnners for an adequate seal. any input would be appreciated. in the past i have tightened the bottoms then the tops and this has seemed to work well but in light of my recent intake dilemna nothing must be overlooked.....
edit...no image attachments not technically related to the post
Old Apr 26, 2002 | 05:38 AM
GKrazy69's Avatar
Not sure of the proper "by the book" method, but here's what I did. I torqued the bottom first then the top, doing the middle bolts first then the ends. I havent had any problems from doing it that way. If you're using a torque wrench I believe the setting is 25-30 ftlbs.
Old Apr 26, 2002 | 12:56 PM
thanx for the reply
Old Apr 26, 2002 | 04:04 PM
Jim 86 IROC's Avatar
Car: 1988 Vette; 1988 IROC Z-28
Engine: 350cid; 305cid
Transmission: 700R/4; 700R/4
Axle/Gears: 2.59; 2.77
I've heard that it helps to retorque them after a heat cycle.
wigmobile
Feb 26, 2025 02:56 PM
Pac J
May 17, 2020 10:44 AM
Rousseau92maro
Feb 1, 2016 05:12 PM
mfp189
Sep 27, 2015 09:25 AM
CatmanFS
Sep 19, 2015 09:00 AM
