Leaky Injector
Old Apr 26, 2002 | 06:24 PM
robert1's Avatar
Leaky Injector
I'm having a problem with an injector leaking at the fuel rail. The O-ring looks ok to me. Other injectors didn't leak either. I put some GM 22# back in an Edelbrock manifold, and #6 leaks at the fuel rail. Could the body of the injector be leaking?
Old Apr 26, 2002 | 07:04 PM
Jim 86 IROC's Avatar
Car: 1988 Vette; 1988 IROC Z-28
Engine: 350cid; 305cid
Transmission: 700R/4; 700R/4
Axle/Gears: 2.59; 2.77
I don't think so. Replace the O-rings.
Old Apr 27, 2002 | 02:02 PM
Swapmaster's Avatar
If you had to pull an o ring out of that hole in the rail with a
screwdriver or something you may have scratched the o ring
bore in the rail. A nasty enough scratch will cause it to leak.
Old Apr 28, 2002 | 09:03 PM
robert1's Avatar
You Were Right
Yes, you were right. The O ring looked ok on the injector, but when I took it off and compared it to a new one, it was kind of oval shaped! Thanks again.
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
