TPI manifold, cold air induction questions
Old Apr 28, 2002 | 09:06 PM
89Irocker's Avatar
Is there any difference in the TPI manifolds between a corvette and a camaro? If so is it worth swapping them? I saw a ZR-1 engine and it looked like it would make a huge difference if you put it's intake/manifold on a camaro, is this possible, or is it even a TPI unit? if so, could you ever find one, and for a reasonable price?
Also, would a home made cold air induction system really add that much power?
Thanks for any responses.
Old Apr 28, 2002 | 09:08 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
There is no difference perfomance wise between vette and f-body TPI. The only differences were cosmestic, the vette being a more rough cast.
As for a homemade cold air induction, a couple of fast cars have already established on the dyno that the stock TPI airbox is superior or equal to something bigger but following a longer path.
Old Apr 28, 2002 | 10:17 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Ahh yes, hes talking about the ZR1 though. A vette TPI is the same as a F-body EXCEPT that the Vette has an external EGR system.
A ZR1 is a different beast all together. It has quad over head cams, 16 fuel injectors (2 per cylinder), and many other differences. Think of it as basically double a regular TPI unit. I would assume that it would not even bolt up to a pushrod type engine either due to the special over head cam 16 valve heads.
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
