Need help to specify an AFR head
Old Apr 30, 2002 | 10:48 AM
primo's Avatar
I need help to specify an AFR 190 head for a 350 TPI for an 87
Iroc. There is some extra machine work needed on the heads for a TPI unit , if you had ordered before please help.
I may used this heads on a stock 350 L98 block or a 383 strocker 1971 block, 4 bolt main.
Thanks for your help,
Old May 2, 2002 | 04:02 PM
tpi_roc's Avatar
Havne't ordered one but you'll want EGR passages if you're staying legal, you'll need temp sensors on each side, and the 3 bolt holes on the front (and back) for accessories, the rest is up to you.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
92projectcamaro
Jan 18, 2016 08:00 AM
New2Chevy
Sep 28, 2015 12:35 AM
z28guy134
Sep 1, 2015 11:50 PM
