1 1/2 hours of polishing my plenum
Old May 3, 2002 | 08:12 PM
92TPIZ28's Avatar
Car: 1992 Camaro Z28
Engine: 355
Transmission: T-5 w/centerforce dual friction plate clutch
i have been sanding my plenum for over an hour now and it didn't change that much. it is a lot smoother and a little bit shinnier, but not even close to done. is this how usually long it takes?
Old May 3, 2002 | 08:21 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
now which is it? sanding or polishing? Sanding is just that, sanding. If you have smoothed the plenum to your satisfaction, then begins the polishing, using compound and a buff wheel mounted on a bench grinder, drill, dremel. Starting with the course compound you polish the plenum, going with finer compounds (and clean buff wheel), til its mirror shiny. Check out this thread for good info and links. cheers, Bob
https://www.thirdgen.org/techbb2/sho...hreadid=103187
Bubbajones_ya
Oct 25, 2015 08:01 PM
bigjay89gta
Oct 15, 2015 08:04 AM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
gord327
Sep 29, 2015 10:18 PM
