Pics of polished plenum
Old Apr 27, 2002 | 04:23 PM
johndo1707's Avatar
It took me about 2 hours to make it look like this, i started with 80 grit and ended up with 800 grit and used the mothers aluminum polish to clean it up. looks great! i also ported it for my slp runners and ported the whole plenum, car runs great now!
Old Apr 27, 2002 | 04:24 PM
johndo1707's Avatar
another pic
Old Apr 27, 2002 | 04:25 PM
johndo1707's Avatar
porting
Old Apr 27, 2002 | 04:26 PM
johndo1707's Avatar
forgot pic,lol
Old Apr 27, 2002 | 04:40 PM
johndo1707's Avatar
look at that reflection
Old Apr 27, 2002 | 06:43 PM
87_Camaro's Avatar
that looks very sweet indeed
Old Apr 27, 2002 | 06:50 PM
SMKNGTA's Avatar
Car: 1989 GTA
Axle/Gears: 9bolt 3.27s
That looks awsome, nice job. What did you do the porting with? How long did the porting take?
Old Apr 27, 2002 | 07:04 PM
360Iroc's Avatar
can you explain the porting on the front of the manifold? What is being removed there. I havent looked at one in so long i forgot...
edit: looks good btw i have my runners polished but not the plenum, i know what im doing next week though...
Old Apr 27, 2002 | 09:47 PM
88ROC1LE's Avatar
LOOKS GOOD
Old Apr 28, 2002 | 02:08 AM
Kandied91z's Avatar
looks nice, a little more work and it will look like a mirror.
this is just an idea, but you might want to try different polishing compounds; mothers works, but there are better as well as mothers will haze quickly as well as fill in the metal with rezidue causing dullness........
try a company called wizards if you can get your hands on it. works wonders over mothers ten fold an leaves much less resude.....meaning less work and more shine.
Old Apr 28, 2002 | 01:32 PM
johndo1707's Avatar
thanks guys! yea, i want it to look like a mirror, i'll prolly finish it up some other time, but i'll look for that other polish. mothers is good, but it does seem like the residue is still on it sometimes and it dulls out really quick like dirt or somethign is sticking to it. thanks!:lala:
Old Apr 28, 2002 | 01:47 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
check this out to get that mirror finish.
http://www.eastwoodco.com/cgi-bin/sg...02042814445730
looks good, bob
Old Apr 28, 2002 | 02:04 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Axle/Gears: 3.23 Dana 44
For you all are wondering how to do it...
http://www.gmtips.com/3rd-degree/dox...m/pol-plen.htm
Heres some pics of what the guys plenum looks like...
Old Apr 28, 2002 | 02:54 PM
87_Camaro's Avatar
i'v read that, it's really informative.
Old Apr 28, 2002 | 07:30 PM
johndo1707's Avatar
wow, that one came out great too! that must have taken forever, i just did the top of mine, all those spots on the sides and stuff had to be tough and take a while. i think i'm gonna try and get it even smother, thanks!
Old Apr 28, 2002 | 07:53 PM
87transam5.7tpi's Avatar
ya mine looks like that guys, I have about 30 hours in mine. I did top,sides and bottom. I'm still not satisfied though, so this summer I'm gonna redo it I think.
Old Apr 28, 2002 | 10:43 PM
johndo1707's Avatar
damn, mine took me a total of about 3 after it was all finished and i only did the top, the sides look like they would be a bastard to do. i guess it's worth it if you have the time, i definitely dont. keep up the good work
Old Apr 28, 2002 | 11:08 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Tools to speed up the job - orbital sander, dremal, and the proper buffing wheel and compound.
This is the site I used to chose the right buffing equipment..
http://members.aol.com/mmmm999/3rd-degree/tips/buff.htm
Old Apr 28, 2002 | 11:37 PM
here is some pics of what 70 hours will get ya :-)
Old Apr 28, 2002 | 11:38 PM
Old Apr 29, 2002 | 03:12 AM
jarek5_7's Avatar
here`s mine
it took me lot more time
Old Apr 29, 2002 | 03:13 AM
jarek5_7's Avatar
andf another one
more on
http://www.jarek.arjmm.pl/tech/plenum/plenum.html
Old Apr 29, 2002 | 07:44 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Wait until you start sanding the runners. The driver's side SLP runner casting SUCKS. I gave up and used a d/a sander on it.
Old May 1, 2002 | 10:28 AM
cort351w's Avatar
Very nice.
Old May 1, 2002 | 01:52 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Axle/Gears: 9 bolt / 3:70
Check these pictures out...
http://www.geocities.com/jasonaschle/
Old May 1, 2002 | 01:54 PM
RU-QWIK's Avatar
Car: 91' Camaro
Engine: 383 ci
Here is the second page...
http://www.geocities.com/jasonaschle/photopageflag.html
Old May 1, 2002 | 03:18 PM
Guido's Avatar
Car: 2000 Trans Am
I once polished a Mustang 5.0 stock upper intake to a mirror shine. After the powdercoating was removed, I started wiht 400 on a black & decker power sander. Then moved to 1000 wet. Then 1500 wet. then finished with 2000 wet. I had about 7 hours in it and most by hand except the initial 400 on the decker sander.
Looks great guys!
Old May 1, 2002 | 03:48 PM
Ron Mullins's Avatar
Are you gonna take more material off the tb area?
Old Apr 14, 2003 | 12:04 AM
bigals87z28's Avatar
Car: Check The Sig
heres what i got with 400 dry still gotta work on it
Old Apr 14, 2003 | 12:07 AM
Car: Check The Sig
there are tuff to see.. but i tried to make them clear
Car: Check The Sig
sorry.. heres another bad shot... hehehe
Old Apr 14, 2003 | 03:19 AM
easySPEEDcamaro's Avatar
Car: 1992 Camaro Z28 Anniversary Edition
Transmission: Borg Warner 5-Speed
just so you dry guys know, you won't get anywhere polishing unless you switch to wet...
Old Apr 14, 2003 | 04:10 AM
Car: Check The Sig
i know.. but i havent been home to finish up in a long time. stupid college... miss my baby
Old Apr 14, 2003 | 08:32 AM
Jim85IROC's Avatar
wet what? You mean wet sanding? All that does is keep your paper from plugging up.
Old Apr 14, 2003 | 03:21 PM
Christos's Avatar
Car: 1986 Iroc Camaro
Transmission: Th700R4 Jr. Raptor
Nice photos and links here.
I was curious about wet sanding myself. Do you normally use oil? Or just water? I have heard that both work.
Old Apr 15, 2003 | 01:51 PM
Cruzin Kaz's Avatar
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Axle/Gears: 3:73 Posi
Looks good! I took mine right up to 1000 wet sand, then a 3 stages of buffing compounds, but I am going to finish it off with 1500 and 2000 wet micro. I will, by then have a total of 20 hours into the TB and the Plenum.. Now I need to buy a Vette Plenum extension and polish it to match...
here are some pics.
Old Apr 15, 2003 | 02:03 PM
Car: Check The Sig
Hey cruzin, how did you paint your TB plate? i wana do the same, and have the letters a different color. how did you do it and are there any links to sites saying how to do it?
Old Apr 15, 2003 | 02:10 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Basically I degreased it very well, gave it a light sand/scuff to give the primer something to stick too, then painted it. Once completely dried, I sanded the letters very carefully then gave it 3 or 4 coated of high heat ceramic clear coat. It is very easy to do really, just make sure it is clean and dry before you move on to the next step...
Old Apr 15, 2003 | 02:40 PM
iroc4ever's Avatar
Car: 1989 Iroc-Z
Axle/Gears: 2.73 (for now)
That TB plate looks very nice!! I think I got myself a project for next weekend after I take my car out of storage.
Thanks for the tips Cruzin
Old Apr 15, 2003 | 02:58 PM
Car: Check The Sig
very nice man.. i like it.. i might go with a different collor then white on the letters..
Old Apr 15, 2003 | 03:15 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Actually the letters are not white..I just use a sanding block with 120 grit sand paper to scuff the paint off back to the aluminum finish. After I had the letters just right, I applied the clear coats.
I am more then happy to have helped anyone, if you have any other questions..just ask, if you can't or don't want to do it, I can do it for a small fee + shipping..I know alot of people will tackle this them selves, but it's what I do, so I thought I would offer my services too..
Old Apr 15, 2003 | 04:38 PM
iroc4ever's Avatar
Car: 1989 Iroc-Z
what grit did you use for that light sanding??
Old Apr 15, 2003 | 08:56 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Just some 400 dry to scuff it some
Old Apr 17, 2003 | 01:57 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
Heres a couple of mine:
Old Apr 17, 2003 | 02:01 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Old Apr 17, 2003 | 02:06 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Last one...
Old Apr 17, 2003 | 02:23 PM
Cruzin Kaz's Avatar
Engine: T.P.I L98.
Very Nice!! I gotta get me one of those...:hail:
Hotrodboba400
Dec 10, 2019 07:07 PM
Breazlan
Sep 25, 2015 11:20 AM
Nick McCardle
Sep 10, 2015 08:36 PM
scottmoyer
Sep 7, 2015 07:06 PM
