Car pinging at high rpms
Old May 3, 2002 | 08:03 AM
NEOMASTERZ28's Avatar
Car: 85 z28
the car is pinging some time when the car is cold and most of the time when the car is hot i use 93 octane gas and i just put a new timing chian the timing is perfect on 6 degee thats what the factory sticker says.
a buddy of mine told me to open the trottle and put water in it to take out some carbon or something that makes it ping
any body can help
Old May 3, 2002 | 10:43 AM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
Stock dampers are notorious for shifting as the inner and outer rings are not one piece but held together by an elastomer. If this started after changing the timing chain I would verify that your damper timing marks are correct.
Your friend is talking about blowing out any carbon deposits which cause detonation. It's easier with a FI car to just use a good FI cleaner, it will remove carbon deposits when you go WOT.
Old May 3, 2002 | 11:35 AM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Not to mention the fact that your friend is dead wrong...using a product like Seafoam to clean carbon deposits through a vacuum line is OK...just make sure that you don't hydrolock the engine by inducing too much Seafoam at one time.
Yeah, pouring water into the TB is never a good idea.
Good luck,
Old May 3, 2002 | 12:27 PM
Bort62's Avatar
Since When ?
Ive strait taken a Garden hose to Mine, with no Ill effects.
Old May 3, 2002 | 12:29 PM
Engine: LS3
Transmission: 6L80E
Good one
Kind of like washing the engine compartment with the hose and shorting out the alternator
Old May 3, 2002 | 12:35 PM
Car: 85 z28
everything is new even the damper i changed the chian cause of the pinging. can it be that the valves need to be adjusted ?
Old May 3, 2002 | 12:41 PM
Engine: LS3
Transmission: 6L80E
How many miles on the engine? Oil consumption causes pinging too...usually pretty big consumption...
The hydraulic lifters take up the slack in the valvetrain, so unless you are running a solid lifter cam...don't worry about it.
Old May 3, 2002 | 01:34 PM
rhuarc30's Avatar
Could be a number of things, carbon deposits, AND NO the water trick does not hurt the engine, if your careful, but you could clog your cat if your chambers have a lot of carbon, I like to to it with B12 chemtool though instead of water. There is some really (don't remember the name) good stuff that hooks up to your fuel rails.
Could be lotsa other things though, leaning out at higher rpm's, A vacuum leak, burning oil as the one person said, and even new dampners don't always line up exactly right with the timing marks, but you usually have a couple degree's leeway before detonation on a stock motor, could be poor coolant circulaton causing hot spots around the combustion chambers.
All kindsa things can cause detonation, and some feed into eachother in kind've a viscious cycle. Start by running some cleaner through thoguh, that's the most common.
Old May 3, 2002 | 03:17 PM
MikeH's Avatar
Car: 90 IROC
Engine: 406
Transmission: GMPP 93/4L60
Axle/Gears: 9 bolt 3.27
What is your setup? Carb, EFI?Its getting so hot down here now that doesnt help much. I was getting alot of detonation from my new motor. I tried everthing found out when the new exhuast went on that one of the cats was blocked. Still made over 300 rwhp with a blocked cat.
How is the fuel pump? Maybe not keeping up with the demand on the topend. Is this a new combo? maybe just need to drop back on the timing in the rpm where its pinging.
Old May 3, 2002 | 04:31 PM
Engine: LS3
Transmission: 6L80E
Good luck on the water deal...I can afford cleaner in the can...
Definitely adjust the timing if you are able...
Old May 3, 2002 | 10:36 PM
mckenzie's Avatar
i saw a fellow student in college adding water to his 2.5 liter s10. needless to say, the following week he was replacing his motor. come to find out, he had a huge hole in the #1 piston. if you must use water, please use a spray bottle, and apply it in a fine mist. best of luck, tom
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
specialized
Jun 18, 2022 09:26 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Linson
Aug 21, 2015 02:12 PM
hokis
Aug 9, 2015 03:57 PM
