Plenum Porting Runner Gaskets
Old May 3, 2002 | 09:42 PM
d4nk's Avatar
Car: 86 T/A
Engine: 383
Axle/Gears: 3.27 9 bolt
I jus yanked the plenum off n got some siamese runners and was wonder if i should just cut the gaskets and siamese the plenum openings.
Matt
Stock Firechicken
Old May 4, 2002 | 09:05 AM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Well that would be what most people do in your situation
Old May 7, 2002 | 11:28 AM
tpi_roc's Avatar
YAP
or get a TPiS big mouth gasket and gasket match to that
but thats more or less for the opposite side.
Old May 7, 2002 | 02:08 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
if you don't siamese the plenum, you'll get virtually no gains from the SLP runners.
MR Gasket sells a TPI gasket set with the larger diameter opening. If you want, I can get the part number off my package tonight.
Old May 7, 2002 | 03:23 PM
Ed Maher's Avatar
Car: 04 GTO
If you have it laying around Jim, i'd appreciate it if you'd post it. I need to order some stuff from summit tonight and could use some bigger opening gaskets, rather then having to worry about making a template to match future gaskets too
Old May 7, 2002 | 06:22 PM
Jim85IROC's Avatar
I believe it's the MRG-146 kit. This is called the upper runner kit, but it's got everything you need to replace the runners.
88SS6SPEED
Nov 11, 2015 07:05 AM
Chas91Z28
Oct 22, 2015 10:12 AM
italiano67
Sep 22, 2015 08:42 AM
toronto formula
Sep 10, 2015 07:31 AM
hdis2002
Sep 8, 2015 02:52 PM
