What injector # is too big for stock 5.7
Old May 5, 2002 | 01:50 AM
ULLOSE2's Avatar
I need to replace my injectors on my 87 gta 5.7 and I was wondering if the #24 injectors would be ok to install. It is a stock motor with the only mod being a k&n filter and screens removed from the maf. any information would be helpful. Jim
Old May 5, 2002 | 01:57 AM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
The stock ECM is supposed to be able to compensate for up to a 15% bigger injector. So yes a 24 lb. injector will be fine.
Old May 5, 2002 | 06:35 AM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
The ECM does not "compensate" for a larger injector. The only was to change the injector size is to reprogram the "injector constant" inside the prom.
With no others mods other then a K&N air filter changing from 22lb to 24lb injectors is a waste of time and you will see NO increase in power. All that will happen is your gas milage will suffer and you get to smell raw unburnt fuel all the time. Stock TPI's run rich anyway, don't make the situation worse. Take that injector money and get headers and a cat back system, follow up with a cam if there's any money left over.
Old May 5, 2002 | 08:29 AM
ULLOSE2's Avatar
My injectors are the main problem now, I have 4 of them leaking down. My gas mileage is terrible and it is very hard to start, lots of black smoke after it cranks up.
I can't seem to find a good set of #22 injectors but there are a lot of #24's out there at good prices.
Old May 5, 2002 | 09:48 AM
Mark 89Formula's Avatar
Look for a set of the new Accel injectors. They have part numbers for 21 and 23 lb/hr along with quite a few others. Either of these would work better than 24 lb/hr. I got mine from Rich at Cruzin Performance.
http://www.cruzinperformance.com/
Old May 6, 2002 | 02:31 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Actually, the answer depends on how much you are going to build up your engine in the future. If you can burn a prom and change the injector constant, then go with the 30 lb/hr. Why? Because they are just a little bit more, will have good resale value and will work on a stock engine (with the injector constant changed).
HTH,
Orr89RocZ
Apr 25, 2016 08:28 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
ezobens
Aug 19, 2015 10:29 PM
jharrison5
Aug 19, 2015 05:53 PM
sreZ28
Aug 14, 2015 07:48 PM
