Anyone else have this happen to them after filling up with gas?
Old May 5, 2002 | 02:49 AM
Night Hawk's Avatar
Does anyone other than me notice that there TPI starts up quicker after filling up at the gas station? My GTA usaully cranks over a little before actually starting up, but when I stop at a gas station and put gas in, the car starts instantly. The GTA also starts up quickly if I let it sit for anything over 3 days.
Does anyone else have this happen to them? Does anyone have an explaination for this?
Old May 5, 2002 | 05:44 AM
89Warbird's Avatar
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
Mine usually starts the quickest when I ask it if it wants to stomp a Ford. Other than that, no, no difference.
Old May 5, 2002 | 10:58 AM
90Form350's Avatar
My car cranks for awhile when hot, and when i let i sit overnight it starts right up the next day. Haven't figured it out yet. nice looking car btw night hawk.
Old May 5, 2002 | 01:06 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
90form350
might want to check your injectors. they could be leaking. i currently have that problem.
Turns out i even have 2 injectors cold ohming at 9.9 and 10.7. bad injectors
Old May 5, 2002 | 01:26 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
My TPI just starts up faster when it's warm. Maybe you have a leaky charcoal canister solenoid or something and when you open the gas cap it bleeds off the pressure.
Old May 5, 2002 | 01:32 PM
trans87's Avatar
Car: 2006 Tacoma X-Runner
Engine: 4.0L DOHC V6
Transmission: 6-Speed Manual
Axle/Gears: 3:15 LSD
I don't notice any difference when I start up after filling with gas. I do notice my exhaust echoes better though under the gas station cover
Old May 5, 2002 | 05:25 PM
90Form350's Avatar
would bad injectors cause a rough idle and engine shake?
Old May 5, 2002 | 06:27 PM
CamaroX84's Avatar
Sure can. How many miles are on those injectors? My car did this and hardly ran down the road at all. I was lucky to get it home. Use an ohmmeter and check the resistance of your injectors. I forgot what they are supposed to be. That's what I did, and mine were bad. Threw in a new set and the car fired right up nice and smooth. Hope this helps. Good luck.
Old May 5, 2002 | 06:58 PM
Beefy89's Avatar
lmao!!!!!!!!
Old May 5, 2002 | 07:08 PM
Bort62's Avatar
The only thing I notice after filling up is that My right buttcheek sits in the seat a little better.
Old May 5, 2002 | 08:43 PM
90Form350's Avatar
the injectors have 148,000 on them, but the car ran smooth as hell until i put the new motor in, that was at 145,000.
Old May 5, 2002 | 09:03 PM
bigals87z28's Avatar
Car: Check The Sig
bort62.... that was great!! i dont wana start a whole nother convo... but my gas prices are coming down.....they were 1.51 for high test (93) at sunnoco... i now its like 1.45... all i know is the super high (94) is still like 1.61... so i only go 94 when im in the mood aka got my pay check.... what i find crazy about my car... it gets better gas milage then my taurus... i got like 22 mpg in the Z... and like 19 in the taur-a$$....and another thing... does this happen to anyone... when i have a friendly outing with a rice-mobile.... and i gunn it... my gas gauge goes up and i gain like an 1/8 to a 1/4 of a tank? ... but then drops down...its strange... aight peace...
Old May 5, 2002 | 09:35 PM
87GTA57L's Avatar
wow, thats kinda halirious!
I have a little suspicion that maybe when you take off your gas cap, your gas tank vents.(sometimes you hear that hissing noise)
maybe it could have to do with that? maybe your purge solenoidfor the tank vent?
just a pathetic guess!
bigals87z28, i think thats because wen you come to a stop,
all or most of the gas goes to the front of the tank, and same when you accellerate the gas goes to the back of the tank. its just because the float goes up and down in the tank. its typical, dont worry bout it.
87GTA57L
Old May 6, 2002 | 09:50 PM
Car: Check The Sig
thats what i thought.... but the increase was so large...i was thinkin it was somethin else... dunno what...but i thought it was something else..... aight peace
Old May 6, 2002 | 10:12 PM
Swapmaster's Avatar
The only thing I notice when I fill up is that my wallet gets lighter.
Dual tanks, takes about $35 to fill the damn thing. And that's
only good for a day or so, I have a lead foot.
Old May 7, 2002 | 10:04 PM
Night Hawk's Avatar
Yeah my when I take the gas cap off, it releases a ton of pressure, hisses fairly loud. When I put the gas cap back on and start the car, it starts great! Could one of these solenoids be causing my problem?
Old May 7, 2002 | 10:53 PM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
The hissing sound is air rushing into the tank, not out of it. Late TPI systems had an unvented system (EPA bs) that had a vacuum line to the cannister to suck gas fumes into the engine. There is, or should be, relief solenoid controlled by the ECM. Check for proper operation. Hey bigal, you probably lose an 8th to a 1/4 tank when you slam on brakes and cause fuel to dam up on front side of tank and change float level just as it dams up to rear of tank when you kick it.
Old May 8, 2002 | 07:43 PM
Car: Check The Sig
72LT1VETTE, i dont loose gas i gain a 1/4 to and 1/8 everytime... then i drop back down to what it was at before......
Old May 8, 2002 | 07:48 PM
360Iroc's Avatar
hes explanation speels it out for you
i noticed the same thing my car starts quicker when i fill up...
Old May 17, 2002 | 01:19 AM
Night Hawk's Avatar
How do I check for proper operation of the relief solenoid?
Old May 17, 2002 | 08:17 AM
87irocz350's Avatar
Car: 87 Iroc
Transmission: T-5 3.42's
Yeah, when ever I floor it the gas goes up!. But thats cause the gas goes to the back of the tank. When I press on the brake the gas goes down.
So you know what my car sayin. Keep the pedal to the metal:rockon:
Old May 17, 2002 | 08:35 AM
Brian'sIROC's Avatar
My car does the same thing also. Starts right up after a fill up, and first thing in the morning. Any other time I have to crank it over a bit before it starts. Is this relief solenoid on top of the charcol canister? Is there a way to test it?
Old May 17, 2002 | 09:24 AM
mean 5.7's Avatar
Car: 87 gta
Engine: 5.7 ltr
Transmission: full race 700r4
just to add my .02 cents i had the same exact problem
could be a leaking pressure regulater
pull the vac hose off if there is any fluid in the hose it is bad replace it the diaphram in the regulater is leaking if this is the problem now is the time to install a adjustable regulater
(not the b&m it is poopy)
i replaced mine and whala fired right up and has not missed a beat since
chazman
Aug 28, 2018 03:25 PM
1fast91
Sep 8, 2015 01:48 PM
chazman
Aug 22, 2015 02:01 PM
BurlyChev
Aug 16, 2015 09:08 PM
