Trick Flow 23 degree heads and gasket thickness??
Car: 1989 Iroc-Z
Engine: 350ci SBC
I was thinking about getting the Trick Flow 23 degree heads that are cnc ported in the 64cc versions. I have heard that after the cnc port they are now 66cc. Trick flow recomends the use of these felpro gaskets:
Fel-Pro 7733PT-2 for mild engines up to 4.060 in. bore
Fel-Pro 1010 for high output engines up to 4.155 in. bore (will not indent aluminum heads)
I have a stock 350 that has never been touched. I assume that I need the Fel-Pro 7733PT-2 for mild engines up to 4.060 in. bore gasket. Now my question is.....is there a slighter thinner gasket that I can use to bring the head cc back down to exactly 64cc. If there is will there be any problems that I could run into like sealing and the such....
Also where is the cheapest place I can get the TFS-30400006-CNC heads from.
Thanks!!!!
Thanks!!!!
Car: 89 formula
Engine: 383
Try www.jdsperformance.com best prices I could find.
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
Felpro makes a coated 1094 steel shim head gasket that has a compressed thickness of .015. I would call up Trick Flow and ask them about the use of that gasket with their heads.
Anyone ever use the 1094 head gasket before? I just bought some Trk Flw 23s & I have those head gasket sitting in the box. Do these head gaskets need anything special to install them? Do they need to be retorqued?
njdaewoo
njdaewoo
Car: 1989 GTA Nighthawk
Engine: 389 CID TPI
Transmission: TCI 700R4
Axle/Gears: 9 bolt 3.23
Going from 64cc to 66cc you change from 9.5:1 to 9.3:1. If you use the TPIS head gasket, using .026 thick then your compression ratio will be 9.65:1. If you use the steel shim gasket, not a real good idea since they aren't intended for street use, your compression ratio will be 9.9:1.
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
I have used the coated 1094 steel shim gasket many times and there is no problem with street use. The gasket needs a smooth head surface and block deck to work but I have installed these gaskets on used non resurfaced engines with no problems.
Mickeyruder
Sep 2, 2015 02:45 PM
355tpipickup
Aug 27, 2015 08:13 AM
NinjaNife
Aug 23, 2015 11:49 AM
Dialed_In
Aug 20, 2015 01:45 PM
