running way too rich...
Old May 6, 2002 | 11:21 PM
BigMInstalls's Avatar
my car is a 5.0 TPI, '91Z28, the car won't idle when it's cold, and when the engines up to temp, it runs really rich, very rich. I bought a new idle air control module but haven't had the time to put it one yet, does any one know what this sounds like?
Old May 7, 2002 | 11:11 AM
tpi_roc's Avatar
Maybe a dead 02 sensor?
Or a broken FPR ?
Old May 8, 2002 | 12:39 AM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
O2 sensor is not in the loop when cold. First, check for vacuum leak or loose hose to MAP sensor. Then check CTS sensor. Next problem areas, fuel pressure and leaking injectors.
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
