correct Idle and Tps settings??
Old May 7, 2002 | 07:36 AM
KYL98's Avatar
Car: 1991 Z28
I have a question. I recently purchased another 91 Z motor with the speed density setup. The originally setting for the idle has been altered and the tps is the non adjustable one. Where can I find a voltage reference for the tps sensor? and does anyone know what the idle should be close to? the timing is set at 8 deg. initial, about 35 deg at 3000rpm if that may have anything to do with it.... and finally, does anyone happen to know if I can use my tpi setup on my 406 motor Im working on???? Thanks in advance
Old May 7, 2002 | 11:07 AM
tpi_roc's Avatar
Re: correct Idle and Tps settings??
https://www.thirdgen.org/newdesign/tech/tpimod2.shtml
^^ setting tps
Idle should be about 1,100 at start up on a cold morning, it'll settle to about 700, then about 500-600 in gear.
yes it will FIT on a 406, but will it *WORK*? that depends on what you want. You'll get monster torque, then run out of breath at about 3,000 rpms
I'd say you'll hate it if you're looking for any real performance, you just can't breath with a stock 305, even the tpi from a SD 350 was still designed for a 305.
Old May 7, 2002 | 05:34 PM
KYL98's Avatar
Car: 1991 Z28
The setup is coming off a 350. And I am probably going to put the bigger throttle body, runners, etc. You still think it wouldnt be able to breathe with that? Id hate to have to go with a carb or something.....I wanted it to look semi-stock anyway....ANyone have any info on the tps settings? Thanks for the info dude...
Mike
Old May 7, 2002 | 05:37 PM
tpi_roc's Avatar
On a 406 a fully modified TPI (LTR) setup is STILL small, You're in the miniram/superram/lt1/t-ram/stealth ram stage
406's sure need to breath
Old May 7, 2002 | 07:08 PM
KYL98's Avatar
Car: 1991 Z28
Would a Hogged out LT1 intake work on it? What kind of price am I looking at for an intake to work? or should I just put a carb on it?
Old May 7, 2002 | 07:09 PM
tpi_roc's Avatar
Buy an intake ($65) send it to john millican ($200) install it (free/+gaskets) and hold onto your A5S
Old May 7, 2002 | 07:12 PM
KYL98's Avatar
Car: 1991 Z28
One more question, Do you know anyone that can reprogram my computer to control the new engine????
Old May 7, 2002 | 09:14 PM
tpi_roc's Avatar
Ed Write
Old May 7, 2002 | 11:33 PM
72LT1VETTE's Avatar
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
Hey tpi_roc, how do I contact Ed Write? KYL98, you won't have to "hogout" the LT1 to hold on. It'll give you all the boost you want without it.
tpi_roc's Avatar
fastchips.com or something, im not sure
I burn my own
What all are you trying to change?
Old May 7, 2002 | 11:53 PM
72LT1VETTE's Avatar
Engine: 350 HO
Axle/Gears: 336
Need to change chip to compensate for cam and recently installed Motorcraft SHO 24lb injectors. Too little vacuum, to much gas. Running rich.
Old May 8, 2002 | 06:19 AM
KYL98's Avatar
Car: 1991 Z28
Will the LT1 intake bolt up to aftermarket heads???? Im putting in a comp cams .488/.495 112 sep, and have vortec heads on it now....with 1.6 rockers. Ill probably put in some bigger injectors if needed and was going to use the TPI setup with aftermarket runners, base, and polished and hogged out plenum. Will the LT1 intake make enough torque and let the motor breathe....???
Old May 8, 2002 | 09:05 AM
tpi_roc's Avatar
thats why you send it to john, it neesd to be modified
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
mdtoren
Aug 16, 2015 05:45 PM
perZ
Aug 15, 2015 01:17 PM
