TPI Sensor Part #'s
Old May 8, 2002 | 07:19 PM
david auster's Avatar
Car: 1992 Camaro
Engine: 350 miniram
TPI Sensor Part #'s
I just got my engine back from the engine builder and I am getting ready to install it. I built a Speed Density 350 miniram setup. The only sensors I have are the 2 that attach to the throttle body and the 2 that go into the front of the intake manifold(anybody know what they do?). I am not sure of all the other sensors I need, but I know some that I for sure need so could somebody tell me the part #'s for
Map Sensor
Knock Sensor
Oil sender/sensor?? Goes right next to the oil filter
02 Sensor
Temp Sensor?? Goes in the passenger side head
Am I missing any I got the wiring harness just have alot of plugs to fill? Thanks
Old May 8, 2002 | 08:48 PM
Omar's Avatar
The 2 sensors in the throttle body should be your Throttle Position Sensor (TPS), Idle Air Control Valve (IAC Valve).
Knock Sensor - 10456288
O2 Sensor - 25162693
I dont know the rest. But your local dealer could help you out. Those part numbers should be easy for them.
Caspar
Jun 19, 2016 11:19 PM
fonzie85
Aug 13, 2015 11:50 AM
Sanjay
Aug 12, 2015 03:41 PM
squiggy2
Aug 9, 2015 09:30 PM
1nastygta
Aug 8, 2015 07:38 PM
