Tps keeps frying
Subscribe
May 11, 2002 | 07:43 PM
Ok for some reason when i put a new tps on my car it runs fine. when i clear the engine codes and start the car agian te tps is bad again. whats the deal
Reply 0
May 11, 2002 | 10:25 PM
anyone have a clue why.
Reply 0
May 11, 2002 | 10:46 PM
Other than replacing the TPS, have you done any thing else to car recently?
Reply 0
May 12, 2002 | 12:02 AM
what do you mean by bad? is it low voltage or high voltage? are you adjusting the TPS properly when installing it? if you havent do a search on TPS adjustment, I think its actually one of the tech articles off the home page
Reply 0
May 12, 2002 | 10:13 PM
i know how to adjust it. when i install it it works for a minute and then it just bugs out completely.
Reply 0
May 12, 2002 | 10:36 PM
As I ask before, have you done anything else recently? You should see a puff of smoke or the smell of something burning as it goes out. If not, check wiring bundle to see if the center wire has been melted or rubbed and grounded somewhere on the exhaust or frame. Check supply voltage supply and grounded connection. Supply should be 5 VDC. Either the supply is to high or the center conductor is grounded pulling excess current through the resister (potentiometer) to ground. If you removed the throttle body make sure no wires got pinched when re-installed.
Reply 0
May 12, 2002 | 11:14 PM
which of the wires do i check for voltage with?
Reply 0
May 12, 2002 | 11:36 PM
http://www.diy-efi.org/gmecm/ecm_info/1227165/ Go the the link above. Scroll to bottom of page and select page 2 for 5.0 engine. Print all pages, may come in handy again sometimes.
Reply 0
May 13, 2002 | 01:05 AM
If you have a spark plug wire shorting to the block, it can (and in my experience has) fry the TPS in short order.
Reply 0
Subscribe
