Swap LT1 heads to L98 engine?????
Car: 1972 LT1 Corvette
Engine: 350 HO
Transmission: M22 Heavy Duty 4 Spd
Axle/Gears: 336
I know that the LT1 heads use what is called reverse flow for water coolant. Are they chambered to work when installed on an older 350 with cooling through the water neck on the intake?
Nope, you would need to do some pretty major work to make the LT1 heads work with a traditional cooling system. It can be done, but its expensive. There is a tech article some where on how to do it.
Engine: 350 HO
Axle/Gears: 336
What about the Vortec heads you have on your car? Did you bolt them to your original 350 block? Also what intake do you have?
1992 Trans Am
Aug 8, 2015 08:16 PM
