Help me build 327 TPI
Old May 12, 2002 | 07:21 PM
J's86ROC's Avatar
Car: 1986 IROC-Z
Engine: peanut cam LB9
I want to build a 327 and put my TPI on it. I know it would suffer from my stock unit, so what should I go with mini ram, stealth ram? I would be at 10:1 compression, slightly larger than stock L79 cam. 222*@.050 and .447"lift. What else should I do or not do. I would probably also get a TPIS level 5 PROM, either that or learn how to do my own. I know this is a little vague, but I am just at the stage of working all the bugs out of this plan. Thanks for the help.
Old May 12, 2002 | 09:47 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
well, there's really no advantage to using a 327 over a 350 except that it sounds cool saying "327". That being said, I'd strongly reccomend doing a roller cam retrofit so that you can get a cam that will actually work well with a TPI-style system. You're going to need to decide before you build what rpm range you want your power in. Due to the stort stroke and big bore, your 327 is going to work best at high rpms, which means a stealthram or miniram, great heads and a good high lift roller cam.
Old May 13, 2002 | 09:16 AM
5.7lformula's Avatar
m
I was thinking about this same thing. I can get my hands on a complete 327. Needs rebuilt. The only problems that i saw were that there wasnt a place tor the acces brackets. (AC, Powersteering, ect...) Im sure that i could make something or order something though. Will 350 TPI parts fit on a 327???
Jesse
Old May 13, 2002 | 09:54 AM
camaro6spd's Avatar
they should the 350 came from the 327, man a MiniRam and a nice cam....those ricers like High RPMS and think that a motor makes alot of power if it can spin fast....lol....the V8 torque with high RPM power....humm BRING IT TO 'EM!
Old May 13, 2002 | 01:02 PM
Jim85IROC's Avatar
Re: m
Jesse
Those heads are what's known as "camel hump" heads if the 327 was one of the high horsepower variants and not one of the 200hp 2bbl ones. Anyway, the camel hump heads flowed great for a 60s head. They outflow L98 heads even, but compared to any aftermarket or vortec head, they're junk. They're also prone to detonation because of their old-school combustion chamber design. I've got a set of 461s on my IROC and I hate them. I still haven't figured out how to mount my a/c compressor.
Old May 13, 2002 | 11:53 PM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
A 327 is better suited for revs and IMO that L79 cam is anemic. As Jim85IROC, you should look to something else like a miniram or a stealthram. You can port the hell out of it and buy all the overprice "high-flow" runners out there and your TPI system still won't make power up top anyway you cut it.
Of course i'm assuming you want to make some power
Old May 14, 2002 | 09:56 AM
camaro6spd's Avatar
or....you can get away with the LT1 intake.
Old May 14, 2002 | 10:35 PM
realfst383's Avatar
Well camaro6spd, unless he feels comfortable drilling a hold in cast aluminium for his distributor....which I know I don't want to drill cast aluminium...that intake is O. U. T. out
Old May 15, 2002 | 07:08 PM
camaro6spd's Avatar
for $200 he can have it done...even tho if i was gonna spend that much i would just buy a stealthram....lol
Orr89RocZ
Apr 25, 2016 08:28 AM
LT1Formula
20
Nov 14, 2015 12:02 AM
Mickeyruder
Sep 2, 2015 02:45 PM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
