What heads?
Old May 12, 2002 | 08:00 PM
Trent257's Avatar
What heads?
i ahve a gm goodwrench crate 350 tpi, will new heads help get more power?
Old May 12, 2002 | 08:09 PM
Der91Z's Avatar
Car: 1993 Toyota Supra
Engine: Inline 6
Transmission: 6 Speed
Axle/Gears: 3.13
of course heads would help. I would go with AFR 190's or the 195's.
Old May 12, 2002 | 08:43 PM
Gruvin84SS's Avatar
Questions i would like answers to as well
I have a crate TPI as well. The current setup that i have in mind is:
AFR 190cc heads
Ported and Siamesed Base, Accel LTR runners, Ported plenum
SVO 24# injectors
Comp Cam with these Specifications:
* Advertised duration: 282 intake/292 exhaust
* Duration at .050 in. cam lift: 224 intake/234 exhaust
* Gross valve lift: .465 in. intake/.488 in. exhaust
* Lobe separation: 114 degrees
* RPM range: 2,200 to 5,700
Any ideas on or changes to this setup? What would a guess on fly wheel HP be for this motor? I am currently running an SD system and have prom tuning capabilities. Other stuff in sig.
Old May 12, 2002 | 08:56 PM
Der91Z's Avatar
Engine: Inline 6
Axle/Gears: 3.13
I would estimate in the range of 325-350 range. That cam has little lift for that much duration. Is that a flat tappet or a roller cam? I would ditch the cam and get another one with much more lift because that much duration really doesn't help without the lift.
Old May 12, 2002 | 09:02 PM
Gruvin84SS's Avatar
cam lift/duration
it is a flat tappet cam. specs are at 1.52 rockers I am gonna bump the rockers to 1.6 rollers which should increase the lift. This is an emissions leagal daily driver but i want a bit more than what igot now.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
