Iac and minimum air
Old May 15, 2002 | 10:15 AM
snoozeyaloose85's Avatar
Iac and minimum air
Can you just clean the iac without setting the minimum air. My idle is good it is just taking a little longer than normal to come down when I first start it . 85305tpiTA
Old May 15, 2002 | 06:36 PM
Anybody?
Old May 15, 2002 | 09:10 PM
BOTTLEDZ28's Avatar
Transmission: A4
if your idle is taking a little longer then normal to go back down then try cleaning your entire TB. remove the top plate and get a bunch of q tips and clean out all the carbon and junk that has built up. remvoe the IAC motor and carefully clean it. do not use and solvent directly on the sensors. also while your cleaning, do the coolant by pass Free Mod .
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
IROCtometal
Sep 9, 2015 10:01 AM
greenyone
Sep 2, 2015 03:39 PM
