are the A/C lines in the way?
Old May 15, 2002 | 11:17 PM
SMKNGTA's Avatar
Car: 1989 GTA
Axle/Gears: 9bolt 3.27s
I just bought a book that tells you all about your car. It says that when you pull off your intake base and exhaust manifolds that the A/C lines MIGHT be in the way and you need to take the car somewhere that can release the presure in the system. Has anyone done an intake base swap and put headers on a 1989 L98 that could tell me what you did? Thanks
Old May 16, 2002 | 01:06 AM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
Take a look at your engine. Look on the passenger's side for a silverish looking can-like object with 2 or 3 lines coming off it near the back of the engine. That's part of your A/C, and anything connected to it is pressurized. (Very general description.)
When I put my headers in, the A/C was removed. It's possible to remove the exhaust manifolds with the A/C installed, without purging it... it'll just take more time. You should be able to remove the intake without touching the A/C.
My experience is on a 1990 L98.
Old May 16, 2002 | 01:09 AM
SMKNGTA's Avatar
Car: 1989 GTA
Thanks for your help. Did you install your headers without lifting the engine? I have heard that it's a b**** to put headers on these cars and that you have to raise the engine.
Old May 16, 2002 | 08:42 AM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Nope, didn't have to lift the engine. All I had to do was unbolt the coolant line to the heater to move it out of the way, bend some brake lines, and grind a little off the steering shaft.
There's some pictures and a little description of my header install in the middle of this post somewhere.
https://www.thirdgen.org/techbb2/sho...threadid=98211
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
m00n420
Sep 11, 2015 02:39 PM
buckshot63
Sep 10, 2015 09:15 AM
Ironhead38
Sep 7, 2015 02:26 PM
TBRays98
Sep 6, 2015 05:05 PM
