NEED HELP, 383 not running right.
Old May 17, 2002 | 09:57 PM
SMKNGTA's Avatar
Car: 1989 GTA
Axle/Gears: 9bolt 3.27s
I came out of work tonight and started my car after sitting for 4 hours and it died. It started normal but the rpms dropped really quick and it died, it did this 3 times. After that I started it and held my foot on the gas to keep the rpms up, it ran rough for a while until it warmed up, then it ran almost like normal, it was just a little rough and the rpms where a little lower at stoplights. I thought maybe it was just bad gas or a fluke so I floored it and it had the normal lowend power but once it got above 3500-4000rpm it fell on it's face, it didn't have any power at all, then it hit second and it burntout like normal and than the same thing happened once it got up in the rpm's. Does anyone have any idea what is wrong? Any ideas would be helpful. Thanks
Old May 17, 2002 | 11:53 PM
J's86ROC's Avatar
Car: 1986 IROC-Z
Engine: peanut cam LB9
First thing I would do is check for computer codes. Is your SES light coming on?
Old May 18, 2002 | 12:38 AM
SMKNGTA's Avatar
Car: 1989 GTA
I don't have the tools to scan my computer for codes. I do not have any warning lights coming on.
Old May 18, 2002 | 04:00 PM
86FyrBrd's Avatar
Car: 1992 Camaro Z28 Convertible Z03
Engine: 383 SuperRam
Mine did the same thing, but the opposite a while ago. It wouldnt idle or have low RPM's at all without giving it alot of gas without dieing.
If I could manage to keep it going to get R's up it would be perfectly fine, that was the MAF sensor
maybe yours is too.
and I know it should, but when that happened it didnt throw any codes.
Old May 18, 2002 | 09:54 PM
bjankuski's Avatar
Car: 1988 Firbird
Engine: 406
Axle/Gears: 4.10
I believe your MAS is not working, check the MAS and the wiring, also check your computer for codes 43 or 44.
Old May 18, 2002 | 11:33 PM
SMKNGTA's Avatar
Car: 1989 GTA
Thanks for your help guys. I found the problem, it was a loose conection under the plenum. It must have worked it's way loose since I pulled off my TB and plenum a few weeks ago to clean everything.
jhawkeye
May 25, 2022 06:33 PM
Logan Bryant
Aug 27, 2015 11:52 AM
InfinityShade
Aug 22, 2015 08:00 PM
86White_T/A305
Aug 17, 2015 12:16 AM
sreZ28
Aug 14, 2015 07:48 PM
