A/c Compressor and Smog pump Removal
Old May 20, 2002 | 08:02 PM
4:10LT1's Avatar
I am removing my A/c compressor and smog pump on my '88 TPI 305 and am wondering if anyone that has done this what belt length I will need. I am not planning on using an A/C delete pulley. Thanks!
Old May 20, 2002 | 08:13 PM
onetontj's Avatar
I routed the belt around the tensioner on the ribbed side. It seems to work fine and my belt was I think 83.5", but I'm not totally sure.
CJ
Old May 21, 2002 | 09:44 PM
88GTAction's Avatar
I have an L98 so I don't know if they are the same. The hardest thing was getting the brace from the header bolt off, otherwise, it was fairly easy. My belt was 83.5 also, but I'm not sure if they are the same like I said earlier. Good luck!!
Old May 22, 2002 | 01:12 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
If you're serpentine you should need a 96.8 inch belt. Go to the tech articles and you'll find the dayco p/n. If you don't want a dayco belt the shop should be able to cross reference.
Frozer!!!
Jan 19, 2024 04:55 PM
italiano67
Dec 11, 2016 09:21 AM
TheExaminer
Aug 25, 2015 07:34 PM
3rdgenparts
Aug 8, 2015 07:09 PM
mustangman65_79
Aug 7, 2015 09:55 PM
