Cylinder heads/cam
Old May 21, 2002 | 09:34 PM
91 z28 350's Avatar
Car: 91 Z28
Cylinder heads/cam
OK Over the Summer I want to get AFR 190cc SBC Street Cylinder Heads (which plug angle would work best with slp headers straight, angle, or L98 angle plug) and a cam to match my heads is there anything else i should do to make it run right or will it run good just like that. Also eventually im gonna get a lunati 383 stroker kit will the Afrs be good for a 383. Im gonna order all the stuff from Thunderracing.com so they could probally help me while ordering but i just wanna know in advance if this is a good start.
Old May 22, 2002 | 12:05 PM
tpi_roc's Avatar
If you're going to deffinatly run the heads on a stroker you might consider the AFR 195s
Angled plugs or L98 angled plugs will both do you good.
The idea isn't in the angle, but in the spark plug location inside of the cylinder head, the more biased to the exhaust port the better.
FormulasOnly
Jul 23, 2018 08:47 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
meeklay812
Oct 1, 2015 03:46 PM
usafirebird
Sep 29, 2015 11:58 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
