Different throttle cables
Old May 22, 2002 | 02:21 PM
slowTA's Avatar
Car: '88 Formula
Transmission: T-5... in need of slight rebuild
I am trying to put a TPI setup from an '89 and up car into an '86 car. Everything is going OK except for the throttle cable. It has a different end on it that goes into the throtle body.
Does anone ahve some info on this. I'm thinking a cable from an '89-'92 car would work, but do I need a new bracket that bolts to the plenum too?
Old May 22, 2002 | 02:45 PM
tpi_roc's Avatar
You can either change the cable, or the bracket on the TB
Old May 22, 2002 | 03:53 PM
slowTA's Avatar
Car: '88 Formula
Well, it is a BBK throttle body so would it even be interchangable with the stock throttl ebody bracket?
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
L0tuS
Oct 4, 2015 08:07 AM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
