0k , me dumby, can't tell which injectors go where
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
I unhooked my injectors to do the intake and forgot to mark them, How can i tell if they are right? I know about the batch fire thing, but is it important which wire goes to which? I runs pretty good now, soooooo what do i do?
thanks from an air head!!!!!!
it's not important becaus of the bach fire thing it fires all the left at onece then all the right. although they should almost fall in the right locations it dosent matter cause they are spliced together in the harness.
cool, i tried to switch all the 1/3,5/7,etc. but no difference noted. Hence the batch fire is proven. THANX, shaggy
Car: 89 IrocZ
Engine: L98-ish
Agreed, doesn't matter where the injector harness goes...but all injector fire at the same time..assuming my schematic is correct, which only show's one QD driving both injector banks.
thejimsterz28
Sep 15, 2015 04:37 PM
